Anyone in the US Interested in Reflowing an Emitter for Me (Not your usual run-of-the-mill emitter star though.)?
I have a bike light (Ultrafire MT-05S) which I intended to do an emitter swap on the main XM-L2 to a Neutral White Tint (I think it's an XM-L2 T5 5B1 emitter I bought) but ran into a snag when I opened up the light and saw the emitter board. I'm looking for someone in the US that would be willing to handle this for me (it's not a big rush). Here are some pics of the light:
As you can see in pic#2 the outer ring of LED's in on the same emitter board as the XM-L2. The last pic is showing that a 16mm star would mount in that center area IF you cut out that area and mounted two separate emitter boards. I can provide the emitter (I bought a 20mm star, but believe I have extra 16mm's too - standard aluminum stars).
The main power wire (from the battery pack) will need unsoldered in order to pull the pill completely out. There is no thermal compound under the emitter, so that needs added as well. New emitter does not have to be on copper, but if you're willing to tack that on just let me know.
This light has nice thermal properties (that golden "pill" is one piece and visible through the main housing to release heat. The modes are very nice (H-M-L with press&hold for hidden seizure-inducing fast strobe) with a separate switch for the ring light (H-Slow Strobe). According to others, the light pulls from the 8.4v battery pack:
  • high - 0.92A;
  • medium - 0.27A
  • low - 0.09A
so about 1.8A or so to the emitter on high. Low is actually too low for cycling (ok for trailside repair/snack time). If someone feels confident in boosting the output slightly (I am NOT looking for a hotrod, but a good balance of brightness with good runtime) I wouldn't mind that too. It would be nice to have the "low" raised to be more suited for cycling use (slow flat open area riding type use) - which I am sure means raising Medium and High along with it.
By the way, FastTech sent me a regular glass lens instead of the wide angle lens and I am working with them to send me the correct lens (not holding my breathe though).
So anyone interested? You can post to ask questions or for more pics or just PM me. I'm not expecting anyone to do this for free, so please give me your estimated charge for your services.
Thanks!
-Garry
thanks for the pictures, i was interested in this lights from fastech, but wanted to see one dismantled first. I’ve lost my interest now, you saved me some $$
good luck with your quest
EDIT I looked the pictures wrong, i thought it was a hollow pill, but it’s not…
Gary,
Am i correct in seeing that the outer ring of led’s have separate wires from the center XML
Kevin
You just want the XM-L swapped out? Or do you want a copper star in there?
That is one cray cray light and star
Nice light!
My guess is the way to go is take a high power solder iron, put a blob of solder on the tip and hold it right under the led (O.L. style) until it comes of, then reflow the new one in place the same way.
I am in Europe so I can't do it for you, good luck :-)
As djozz said above, you could probably just heat to release the one LED and heat again to attach the other. The extra LED’s around the outside ring don’t have to be messed with. And Kevin, you are correct in seeing that the outer ring of LED’s is a separate circuit, with its own set of wires. Leaftye, he said he isn’t in too much of a hurry, so why don’t you go for it?
Someone experienced at making a stinkpad willing to step up to the plate and put some copper under the emitter?
I would take stab at it.
I would separate the pcb and add a 16mm sinkpad or noctigon. and look for a resistor mod if possible.
@gary…will this be for offroad cycling or on road?
Kevin
Yes, as noted, the ring of LEDs is run by a separate set of wires. I don't know how the driver handles the separate circuits. The light would mainly be used on Rails-to-Trails type trails and maybe some double track, nothing too technical. I like the good balance of flood and throw this light has, though it would be nice to see how it does with the wide angle lens it was supposed to come with!
I also have a SolarStorm X3 to do emitter swaps on, but that one's easy and I like the driver output as-is.
-Garry
Ok, I've lined up a user fairly close by that is going to handle it for me.
Thanks guys!
-Garry
Good luck, gary
Let know how it turns out.
Kevin
