Anyone know the beam angle of the Emisar D3AA or D4V2 floody optic?
Hello BLF,
I’m looking to find out how wide the beam is on the additional wide optic option of the Emisar D3AA or D4V2 - does anyone know?
I ask as I’d like to use it as a reading light, and currently use a 60 degree beaded TIR in a Convoy T5 and T7 but am fed up of their lack of properly low modes even using NiMh.
Any pointers?
I dont know the beam angles, but suggest you buy and try the D3AA with the stock optic.
also order a spare floody optic which you can install yourself if you are careful, if you want an even wider beam
Additional Floody optic ($3.68)
or you can order the D3AA with the floody optic installed, by emailing Hank with your request, by replying to the order confirmation email..
or by emailing him before you order, with any questions
or buy a Dw3AA, with a headband, so you can wear it as a headlamp. It ships with the floody optic, you wont need anything wider
Thank you Jon. May I ask why the D3AA and not the D4? I would have thought the D4 would have a wider beam, and also an even lower moonlight mode given the upgrade to the driver.
Both the D4V2 and D3AA can provide a very low moonlight.. and a very wide beam.
the main difference is that the D4V2 uses a bigger battery
I would choose the D4V2 if I wanted to use a light outdoors while hiking, because the bigger battery will last longer at higher outputs..
i would choose a D3AA for indoor use, such as the reading you describe, because the smaller battery will last a long time at low outputs
both lights will work for reading.. the D4V2 would be better outdoors.. because the D4V2 battery has 3x the runtime capacity of the D3AA battery
I like small lights for indoor uses, but there is nothing wrong with a D4V2 if that is your preference
Thank you Jon for the detailed information on these two.
