So, i saw this tmart BTY 9000 mAh D nimh at tmart.
with their 20% off, and my recent 3D mod i got a bit curious about if these batteries would be better than one or two AA batteries in a D adapter.
I know that BTY usually is crap, but have anyone tested these batteries or heard about them?
OscarM, I don’t have any personally but I doubt they are going to be worth it.I would stick with the Tenergy NiMh ‘D’ cells.They have a very good reputation.-Rick
i don’t doubt that tenergy cells would be better, but i don’t think they are easily available in sweden.
but would the bty D cell be better than 1-2 AA batteries in an adapter? could they have 5000 mAh perhaps?
i probably won’t buy them since i don’t really have the money to waste on such things, and i also lack a charger for them (or maybe my nitecore i4 can charge them?)
BTY is about the same as Ultrafire. Massively inflated claims of mAh plus they will self discharge on you fast. So expect them to be a tenth of whatever mAh they claim and for them to be dead within a short time whether you use them or not. This is what I have read. I don’t know from personal experience so take it with a grain of salt.
yeah, i don’t trust them at all, so unless someone actually have used the cell, or at least heard something good about it i won’t buy it. but still, it would’ve been nice if they at least were an ok budget choice
In a nutshell? Not good. I got a bunch of the BTY AAA cells from Tmart and they were all garbage, 200mAh tops. Rated at 1000mAh; in the bin they went.
This may not reflect at all on the D cells, but I will avoid BTY outright unless someone else has tested and proven them ahead of me. Fool me once…
don’t know, but they have some “8000” mAh D cells for $5,30 each here
the comment/review on the page says they have 5000 mah’s, which at least might be ok for the price?
Yeah that's the one. That review on Manafont it BLF's benckie. Probably not LSD and about the capacity of two really good AA NiMh's so you can decide if it's worth it. Actually you can buy the 3AA holders which are series stock but can be modded to parallel by moving one contact around. I think they only handle about 1A, but if you'd do a Old-Lumens mod to them and replace the contacts with copper they'd pass more. You could also go 4AA.
Hi, i know i bought exactly the same looking Batteries except in stead of 9000mah they are 10,000mah and i intended to use them in a Fenix TK70. But when i use them in the TK70 and turn it on to Turbo mode it kicks straight back to High Mode as that is all the Batteries can handle, even fully charged. They take a Fraction of the time it takes to Charge the Tenergy Premiums i have. The Tenergy Batteries were purchased off Ebay. These run the Torch on Turbo Mode with ease. They seem to give the Torch a Good Runtime as well. I still haven’t had to recharge the first set yet, and i use the Torch often.
I have since purchased another set of cheap “D” Nimh Batteries (Different Brand) to use in my Maglite and Led Lenser, i’ll try them in the Fenix first and if they are any good i will let you Know.
Hope this Helps. Cheers
You might want to look here. And here. Executive summary. If they are branded BTY, they are useless. Check the shipping weight and weigh a decent cell to see how they compare. A good quality 30 year old NiCd D cell I have lying around weighs 132g. A cheap 5000mAh D of recent(ish) manufacture weighs 141g. An 8000mAh LSD D weighs 149g.
Funnily enough, the original link has no mention of weight which immediately makes me suspicious. According to DX they weigh 108g and are therefore likely to be junk.
