Anyone knows what is inside a Black and Decker LBXR12 Li-ion battery pack?
Anyone knows what is inside a Black and Decker LBXR12 battery pack?
i have seen it @ walmart clearance for $10.00 each today. looks like it has 3 cells in it. production date is 2011. 18Wh, so 1500mAh each. i am trying to decide if it is worth buying.
3 high current cells for 10 bucks, looks like a good deal.
they are pbly sony, or samsung high current cells.
well, i went back to walmart to buy this battery pack. i got the last one :slight_smile:
i opened it up, turns out there are 3 Sanyo UF18650W2 inside. each measured 3.88V.
i google the code “UF18650W2” and found out that this battery has a discharge rate of 15A.
so, i am quite happy. except that i have nothing that suck this much current, ha ha.
1500mAh is nothing to get exited about today you can get the TOP OF THE LINE Sanyo NCR18650BF 3400mAh for less then $7 each at BG or Ali E.
Yes and no. If you want high current regardless of run time the 1500mah Sanyo W2s are great cells. I get the schoolgirl giggles every time I open a tool pack with these pink on pink beauties. If you don't care to enter huge amp territory than the NCR18650BF cells are great. Not for me cause I can't do reasonable. Time to get to Walmart.
This is the cheapest 12V Lithium pack I have ever come across. It was at Lowes.
At the same time they had this 5 cell Hitachi Lithium pack.
And the charger for it!
