I’m considering trying it. How hard can it be, right? I’ve got a set of tiny drill bits for my dremel so my first thought is to just clamp the optic firmly and hand-drill the legs. Its small, but I feel like I can do it. But what comes next? Are they normally polished inside? Heat polished? Hot wire? Nothing?
Thoughts?
Alternatively, does anyone do this regularly and then sell the finished product? I’m not opposed to just buying some if someone more experienced can do a better job of it.
I have drilled my optics like you have described, took a dremel bit on my Proxxon hand drill. I didn’t polish anything on the inside because I wouldn’t know how to get into that tiny space. Maybe there are other tools I haven’t used yet.
also haven’t sourced any tritium vials yet.
Thought about this before but never tried it. I think a drill press would be good for this - i wouldn’t try it freehand as the chances of drilling straight & centre would be slim, for me anyway and that would just annoy me :laughing:
Maybe an even smaller diameter rod, trimmed wooden toothpick? with polishing paste on it would tidy it up after drilling.
We did several quad lights for Christmas orders that wanted this. I tried the drilling by hand and it was “ok” but not what I would want to hand to a customer. Finally, drew them in CAD, made a jig, and taught the CNC mill to do the things. Setup was a real…real… ummm…. Anyway, Come to find out, that was the easy part.
Perhaps this will save someone a month of testing… Use in good health!
The hard part was getting a good finish inside the hole. We found that the materials Khatod (not sure that is spelled just right) uses performed the best. It seems to be a tad harder and doesn’t ball up “quite” as bad during cutting. That melted, balled up material causes a really bad finish. I tried steel drills, ceramic drills, diamond drills, carbide drills… all of them left what I call a mess in the finish. Especially right in the bottom of the hole….which becomes the top that is in plain view. Most folks would have been satisfied I think but I wanted the visible part of that hole near polished.
Finally, an Altin coated, 4 flute, ball end mill did the trick. … Mostly. There was still that tiny bit of frost that to me was visible. A combination of slower …yes, slower ….spindle speed, and using a peck drilling method proved to help. A dwell at the end of the total depth helps polish the material. I have a favorite product in the shop for thread lube called Teflon Silicone lube. I detest greasy threads! On a whim, I put some on the end mill and the finish turned near mirror. BEWARE…… you will need a sonic cleaner to get that out of the hole….but it works.
At the end, all it took was forgetting dumping every machining rule known to mankind. Not a big deal! :disappointed: TL
Thought… I wonder if it would be better to drill from the top…. then use some of the Dupont crystal clear Cyno to weld in the vial???
I always set my trits with Norland 61, which is UV glue. Honestly I never would’ve thought to drill from the bottom for fear of messing up how the legs fit against the mcpcb. My plan all along was to drill down through the “face” of the optic and seal the trit inside using Norland.
You guys have definitely given me some things to think about though. TL, it sounds like you’ve tried all sorts of stuff. The “balling” effect of polycarb was my biggest concern, cause I just feel like that hole won’t be very clean once I get it drilled out. I’ll maybe experiment with some teflon lube and see if that helps.
Use a slow spindle speed… I set mine to 400 RPM. I think it took about a minute or so per leg because I had a dwell at the bottom and a dwell at the top of the peck trying to not make plastic balls!! It seemed that slowing the entire process was highly beneficial. Somehow, after melting that material, when it cools it is highly abrasive and much harder than it started out. TL
I think drilling from the top is an excellent idea. Much easier to keep adhesive away from the reflective bottom surfaces and the top is also easier to sand and polish.
There’s someone on the other forum that offers drilled optics for trits from time to time. The holes are drilled from the top and you don’t have to glue them. However, they do move up and down but stay put due to the lens. I glued mine down with norland since I didn’t like the trits moving.
I’d try vapor polshing, pour a little bit of solvent that can dissolve the particular material your optic is made of (aceton would be a good start) in a small “plate” put a little pedestal in the plate to support your optic and isolate it from the liquide acetone, put a glass upside down over your pedestal and let the solvent vapor work, not too long or it’ll melt your optic.
If you use UV glue shouldnt the surface get clean again if you fill the bottom of the hole with a little bit?
Using an injection needle to get a small drop of glue in there.
Or fill the hole with silicon oil and seal the hole with glue?
Filling the hole with enough glue and press the trit inside may be a problem with thermical stress on the trit?
I’ve drilled optics for GITD applications. I’ve done a lot of stuff to optics. There’s an optics-graveyard near my workbench. I can only speak of the PMMA type Ledil Cute as far as drilling goes. For the smaller Carclo ones (PC) I prefer applying GITD to the bottom of legs of the optics.
Not a fan of trits. I am happy with this new strontium aluminate kind of stuff. Also note, drilling and inserting things into the optic should/will lead to a larger absorption of heat by the optic…
For the PMMA stuff it’s important to drill slowly, special drill bit, shouldn’t actually cut but scrape, at least blunten your standard drill bit before drilling PMMA. Use mixture of water and dish-liquid as coolant/cutting oil for example. Take enough time to get it centered from the beginning. Go slow. Drill 1mm, back off and let it cool.
Also, if you haven’t read this Installation guide (pdf file)from Ledil, you probably know a lot more about optics afterwards. Definitely read the “Chemicals” and “Stress cracking” parts if you haven’t.
Great info, thank you Chouster. That PDF contains a lot more than I ever thought I wanted to know about optics
I really don’t know what to do now. I think I’ll still try drilling one for trits. I mean, they’re like a buck each. Not a lot lost if I trash it. I’ve seen the glow powder added to the base of the legs before and I know that works pretty well, but I just like the idea of constant illumination. Hmm…
I think it’s possible. I went with clear epoxy instead, which may have advantages in terms of the bond’s strength. There are other UV glues, also from norland for example, that are made for use with plastics such as PC or PMMA specifically. Maybe NOA 61 will do the job good enough.
I found that PDF very helpful. Maybe would’ve saved me some optics if I came across it earlier… :person_facepalming: :laughing:
