Armytek Barracuda Pro Max review - 2800lm, 1000m
Armytek Barracuda Pro Max was sent to me directly from armytekstore.de for review.
For the flashlight’s technical details and to purchase: https://www.armytekstore.de/
A discount code “Bright15” is available for a 15% discount, which can be entered at checkout.
Immagine
Armytek has recently updated its flagship products, including the new Armytek Barracuda Pro Max. I thank ArmytekStore.de for giving me the opportunity to test the latest version of their highest-performing flashlight in terms of throw.
Armytek Barracuda Pro Max is a tactical flashlight with a focused beam and a long range of up to one kilometer. It is particularly suitable for navigation, hunting, and search and rescue activities. The Armytek Barracuda has been updated in recent years to this new, higher-performance version, which now features two buttons: a new silent tactical button at the tail and one on the side. The aircraft-grade aluminum construction has an excellent anti-abrasion finish. Thanks to a high-performance LED and a smooth reflector, it reaches a maximum light output of 2800 lumens and is powered by a 21700 rechargeable 5000mAh battery (included in the sales package) that can be charged via a proprietary magnetic charger (included).
The Barracuda Pro Max features 5 light modes with a low battery indicator and a maximum battery life of 10 days.
It is IP68 certified (waterproof and dustproof) with a maximum immersion depth of 25 m for 5 hours.
MAIN FEATURES:
  • LED: Unspecified (I think it’s a Luminus SFT70)
  • Optics: Smooth reflector
  • Light output, lumens: 2800 lm
  • Material: 6061-T6 aircraft-grade aluminum
  • Max beam distance, meters: 1000
  • Angle of view: 4°: 55°
  • Number of modes: 5
  • Tactical operation for quick access to maximum brightness and strobe modes.
  • Steel bezel with black titanium coating
  • Real-time active temperature control
  • Full short-circuit protection
  • Can be used with any 21700 lithium-ion battery (also compatible with 18650 lithium batteries or 2 CR123A batteries)
  • Maximum battery life: 10 days
  • Matte anti-abrasion finish
  • Waterproof and dustproof standard: IP68
  • Safe immersion depth: 25 m
  • Safe drop height: 25 m
  • Operating temperatures: -40 to +40 °C
  • Battery status indicator and low battery indicator
  • 10-year warranty
Dimensions and weight
Head diameter: 64 mm
Body diameter: 25.4 mm
Length: 188 mm
Weight (without battery) 256 g
Weight (with battery) 329 g
*Warranty and Support
Armytek provides free warranty repairs for 10 years (excluding batteries, chargers, mounts, switches, and connectors, which have a 2-year warranty) from the date of purchase if proof of purchase is provided.
The warranty does not apply to magnets, silicone covers for connectors and buttons, silicone mounting rings and mounts, clips, silicone grips, holsters, lanyards, O-rings and pads, or Velcro straps. The warranty also does not extend to damage caused by misuse.
Immagine
Immagine
The Armytek Barracuda Pro Max comes in a beautiful hard plastic case protected by molded foam. The case details the key features of the new Barracuda.
Immagine
The sales package is excellent and complete, including various carrying solutions.
Inside the box we find: Armytek Barracuda Pro Max, Armytek 21700 5000mAh rechargeable battery, proprietary magnetic USB charging cable, holster, steel Clip, 18650/CR123A adapter, adjustable lanyard, silicone grip, 2 spare O-rings, and a multilingual quick start manual.
Immagine
The sales package includes several accessories:
The nylon holster is well-made, simple, and durable, semi-rigid with a button closure. As with other products, the lower part is open, so the tail is unprotected. It has several attachment options: to a belt of any width, to a MOLLE mount, or to equipment using a durable plastic D-ring.
The Barracuda Pro Max stays securely in place once inserted into the holster.
Immagine
The Steel Clip with black titanium coating is suitable for attaching to clothing, equipment, or a belt. It’s short but stays securely in place once inserted into the flashlight. Tactical grip is facilitated by the included cigar grip silicone ring. The clip and silicone ring can be used together.
Finally, the package also includes a high-quality lanyard with a ring and quick release.
Immagine
In addition to the accessories included in the package, the Armytek Barracuda Pro Max is compatible with other additional accessories such as the magnetic weapon mount for quick attachment and detachment with a single movement (AWM), Weaver or Picatinny rail mounts, and universal mounts for attaching the flashlight to various types of weapons. The MRS-02 magnetic remote switch is also available for momentary on (only when the button is pressed) and for continuous light. Easy to attach with a single movement, it is not necessary to unscrew the rear cap.
Immagine
Armytek Barracuda Pro Max is made of 6061-T6 aircraft-grade aluminum with good thicknesses and anti-abrasion matte finish HA Type III 400HV.
Immagine
It holds well in the hand even in rainy conditions with an excellent grip. As in this case, I have always appreciated this type of finish on Armytek torches. The size and weight are significant but not excessive (188 mm and 329 g with battery included).
Immagine
On the head of the Barracuda Pro Max we find a smooth reflector (SMO) with the Luminus SFT70 LED at the center (not specified by Armytek). Armytek Barracuda Pro Max features tempered glass with anti-reflective coating and a steel bezel, for optics protection, with a matte black titanium coating.
Immagine
Even on the Barracuda Pro Max we find numerous writings on the torch that are easily legible.
Immagine
The Barracuda Pro Max’s user interface is controlled by two buttons. The tactical button on the tailcap turns the flashlight on and off, while the side button changes modes. The rubber side switch is slightly raised with a quiet click.
Immagine
Immagine
The tail button, made of metal and rubber, is a two-stage with a nearly silent click. Pressing the button halfway produces a momentary-on light for as long as the button is held down. Pressing it fully down results in a light that stays on until the next press. Because it’s protruding, it’s easy to find and press, but its protrusion can lead to accidental activation.
Immagine
The sales package includes a proprietary USB magnetic charging cable that allows for quick charging even in wet conditions. To charge the 21700 battery supplied with the flashlight, simply attach the magnetic connector to the tailcap. I measured a full charge time of about 2 hours and 45 minutes (max 2A).
CHARGER COLOR INDICATION
Charger not connected:
• Green: Device is in standby mode.
Charger connected:
• Flashing green: Battery voltage assessment.
• Flashing red: Clean the external and internal contacts of the tail cap, as well as the contact areas of the charger.
• Flashing orange: The USB power source voltage is too low to continue charging properly, or there is poor contact between the charger and the battery. Clean the tail cap and the threads of the flashlight parts, or use a different power source.
• Red: Charging at the rated charging current is in progress.
• Orange: The USB power source voltage is too low, the charging current is low.
• Green: Charging is complete.
Immagine
I was only able to unscrew the tail cap of the Armytek Barracuda Pro Max. The central body is smooth, while the head has numerous cooling fins to mitigate the temperature reached when used at higher light levels.
The threads of the central tube arrive well lubricated. They are anodized on the bottom, allowing, by slightly unscrewing the cap, the mechanical locking of the flashlight. At the two poles, for contact with the battery, there are two reinforced springs for better protection of the battery and driver. The Barracuda Pro Max has complete protection against short circuits, even in the event of contact between the magnetic connector and metal objects, and has a double O-ring for water and dust protection with IP68 certification (submersible to 25 meters for 5 hours).
Immagine
The unscrewable tail cap has a battery symbol on it to help you remember the correct orientation (positive pole toward the head). The cap has a small hole for inserting the included lanyard. Since the switch protrudes, the flashlight cannot be placed upright (candle-style).
Immagine
For effective operation of the flashlight, Armytek recommends using brand-name 21700 lithium-ion batteries without PCBs; the included 21700 rechargeable battery with 5000mAh is a 17A discharge current and is protected against short circuit, overdischarge, and overload. You can also use 18650 lithium-ion batteries without PCBs with a diameter of up to 18.7mm and a discharge current of at least 15A, along with the battery adapter. Finally, if necessary, you can also use two CR123A lithium batteries.
Immagine
Immagine
Let’s see Armytek Barracuda Pro Max next to other flashlights:
Immagine
User Interface (UI):
Immagine
The user interface with these two new buttons has completely changed for the better, with quick and easy control.
Armytek Barracuda Pro Max has 5 preset modes. The tail switch is dual-stage, allowing for Momentary-On.
By default, the flashlight has no memory but always turns on in Turbo mode. The memory can be enabled (or disabled) to allow the last mode used after turning off.
Instructions for use (taken from the online manual):
N.B. Before use: Tighten the tailcap completely.
On/Off.
Full press of the tactical button with a click.
If auto-memorization of the last used mode is enabled, the flashlight turns on in the last used main mode or Turbo.
If auto-memorization is disabled (by default), the flashlight turns on in Turbo mode.
Tactical Activation.
Partial press of the tactical button without a click from the off state. The flashlight turns on
in the last used main mode or Turbo until the button is released.
Cycle through constant light modes (except Firefly mode).
Press the side button on the flashlight when it is on. Each press changes modes. The modes cycle. Pressing the side button when the flashlight is off does not cycle through the modes.
Activate Strobe mode (if enabled).
The flashlight is on: Two quick, consecutive presses of the tactical button with a click, with a short pause between them.
The flashlight is off: Half-press the tactical button followed by a quick click, with a short pause between each.
Activate Tactical Strobe Mode (if enabled).
Two quick, consecutive presses of the tactical button with a short pause, starting from the off state.
The flashlight remains active until the button is released.
Activate Firefly Mode.
Press and hold the side button, press the tactical button with a click, while holding
the side button. Release the side button. The next press of the side button will activate Turbo Mode.
Activate Tactical Firefly Mode.
Press and hold the side button, press the tactical button with a half-press while holding the side button. Release the side button.
To enable/disable Strobe Mode.
Press and hold the side button while holding the flashlight on for 5 seconds. The flashlight will flash once. Release the button.
To enable/disable auto-save.
Press the side button on the powered-on flashlight and hold it for 10 seconds. Continue holding the button when the flashlight flashes once after 5 seconds. After another 5 seconds, the flashlight will flash twice. Release the button.
Lockout function. Unscrew the rear cap 1/4 to prevent accidental activation.
Beam and Runtime
Immagine
The Barracuda Pro Max’s beam has a concentrated beam with a focused spot and a narrow spill thanks to the smooth, deep reflector.
The central hotspot, specified by Armytek as 4°, has a smooth transition to the lateral illumination (spill) of 55°. Armytek also specifies that the beam creates a 7m diameter hotspot at 100m. This type of configuration makes the Barracuda Pro Max suitable for medium- and long-range illumination for search, hunting, navigation, or tactical applications.
When tested against a wall, at a short distance, no rings or particular artifacts are noticeable. The lateral illumination (spill) is very bright.
Immagine
The luminous intensity, in candela (cd), was measured at a distance of 5 meters using a luxmeter after 30 seconds from start-up. As can be seen in the table below, the values ​​are excellent, with a range of over 1000 meters achieved in turbo mode.
Immagine
Immagine
Using the OPPLE Light Master, a fairly accurate device even if not calibrated, I measured the CCT color temperature and Ra color rendering index at the highest brightness setting, in turbo mode. The beam color is good and not too cold. The flicker index (risk) is in the green range.
Immagine
Immagine
In the thermal imaging test, the images below were taken 1, 2, 3, and 5 minutes after activating the 2800-lumen TURBO mode.
The Armytek Barracuda Pro Max features a design with numerous cooling fins on the head for better heat dissipation and a spring on the positive and negative terminals to protect the drivers and battery from overheating. As you can see from the runtime graph, the Turbo brightness drops sharply after 2 minutes. This trend is reflected in the temperature, which, after reaching nearly 58 degrees, drops as the brightness decreases thanks to the Armytek Barracuda Pro Max’s active temperature control.
Immagine
Immagine
Runtime tests were performed indoors (approximately 18°C) with the included 5000mAh battery fully charged. I used the LX1330B Luxmeter for the test.
Please note that the values ​​shown in the graphs should be taken primarily as reference values ​​because they were obtained using equipment and environmental conditions different from those used in a laboratory. Measurements made with the Luxmeter report values ​​in Candela (cd) and not brightness (lumens).
The Barracuda Pro Max features real-time active temperature control. When the temperature approaches +58°C, the brightness decreases, preventing overheating of the flashlight and battery, as well as LED degradation.
When the battery voltage drops, the brightness will gradually decrease; when the mode brightness drops below approximately 25% of the nominal value, the main LED flashes twice.
As can be seen from the graphs below, the runtimes match those declared by Armytek.
The first test was performed with the Barracuda Pro Max in Turbo mode at 2800 lumens. The runtime matches the manufacturer’s specifications. After 2 minutes from power on, brightness drops sharply to 1100 lumens. This brightness level is maintained for over 76 minutes before another stepdown to the Main 1 level of 240 lumens. This drop, due to low battery, is signaled by the flashlight with two quick flashes.
The second test in Main 2 mode at 630 lumens immediately maintained a steady performance for over 180 minutes before a sharp drop, again bringing the brightness level back to the Main 1 level of 240 lumens.
The third test with the lowest setting (excluding the Firefly setting) Main1 at 240 lumens also maintained constant brightness for over 540 minutes before starting to decline due to battery life. The battery life of almost 10 hours is excellent.
Immagine
The first 5 minutes:
Immagine
VIDEO Unboxing and Use
CONCLUSIONS:
The Armytek Barracuda Pro Max pleasantly surprised me, starting with the beautiful hard plastic case that came with all the necessary accessories. The materials are high-quality, and the flashlight is well-finished with an excellent anti-abrasion matte finish.
The new Barracuda Pro Max now features two silent switches and an intuitive, simple user interface.
The beam output is impressive, combined with good regulation (over two minutes in turbo mode) and efficient temperature control.
Armytek Barracuda Pro Max is a tactical flashlight designed for long-range illumination with good battery life and excellent water and dust resistance (IP68, submersion depth 25 m for 5 hours).
A very interesting product and definitely recommended.
Roberto M.
------ My Youtube Channel ------------------------------------------------
Thank you for such a detailed and high-quality review! :raising_hands:
Thanks, great product.
Hi roma58! Thanks for the review! I just have some thoughts about it. I find it quite peculiar.
For me it fells less like a review, but rather a… product showcase, or actually just an advertisement?
The way you write the review strikes me as unusual. The post seems to introduce the flashlight and speak about it like a sales representative. You bold certain parts of the texts and they often contain useful information, but often times they’re just the positives opinion of the flightlight. This reminds me of how newspaper ads are structured. Reading (atleast the first half) of the review felt like looking through a product’s page. I often say that a review without any negative comments is actually a product advertisement and you seem to almost never describe the Barracuda Pro Max in a negative light.
Now, naturally, a review should introduce the subject at hand properly, but the way it’s written here makes me feel as if I’m reading a product pamphlet. Like someone trying to sell me a flashlight.
Now, please don’t get me wrong, “product showcases” as I like to call them (basically a review but without an actual opinion of the writer and with little text) aren’t bad by themselves. The reader is expected to make up an opinion on the product themselves, based on the pictures and information provided by the author of the text.
Please understand, I don’t write any of this as an intent to hate on you or your work. Please take it as criticism and a suggestion on how to improve for your next review.
Armytek flashlights are by no means bad products. I tried a few of them and was very often impressed by the build quality, but this doesn’t mean they are perfect. I think any review should highlight both the good AND the bad.
Sometimes us reviewers can get wound up glazing a flashlight left and right, especially when we really come to like it, but we also need to remember what our main task is: to fairly rate a flashlight, and help anyone interested decide if the product is the right one for them.
Your review contains a ton of things that a good review should have:
  • Great pictures from all the angles.
  • Size comparisons to other flashlights
  • Your own measurements
  • Beamshots
  • Even a video version of the review!
But to be honest this feels like such a mixed bag for me. The review conclusion also sounds unusual, the flashlight is described in a very good light, maybe too good? I’d like to hear others’ opinion on this. Hope to see what you’ll review next. Feel free to send me a message when your next review comes, I’d gladly read it.
Additional thing. I first saw your review because of a Facebook post on a flashlight-related group with the title of:
Armytek BARRACUDA PRO MAX. Best Throw Flashlight
This is likely very picky of me, but I don’t like when someone uses the word “best”, especially in this kind of context.
What even means to be “the best”? How do you prove a flashlight can be described this way? In the review itself you only compared the Barracuda to a few other flashlights, but only size-wise. I’d personally avoid such words.
Hi Grzybek, thanks for your feedback. I’ve been writing reviews for over eight years. I’ve done over 150, always presenting them the same way. They’re not strictly technical reviews, but I like to present them graphically appealing.
If you’ve read the review, there are also various tests on the flashlight; in addition to the runtime graphs, I’ve included photos of the light beam on the wall and photos taken outdoors. Using a luxmeter, I also measure the maximum distance reached by the light beam in candelas, as well as values ​​for color temperature and Duv. I also have a FLIR thermal imaging camera to record heat distribution, including temperature. Do these things sound like a presentation to you? My review includes videos of the unboxing and use of the flashlight, etc. Each review takes about 10 days of full immersion.
If the flashlight has any obvious or specific problems that I don’t like, I’ll let you know. I’m sorry you didn’t like the review. I’ve had a lot of praise for what I do, but everyone has their own preferences.
Regarding the Armytek Barracuda Pro Max, I truly consider it the best 1,000-meter flashlight I’ve reviewed.
Roberto M.
