Armytek Prime C2 Pro (Warm) review - 2230 lumens
Armytek Prime C2 Pro Magnet USB (warm) was sent to me directly by Armytekstore.de for review.
For technical details of the flashlight and for purchase: https://www.armytekstore.de/
A discount code “Bright15” is available to enter during purchase.
Immagine
Armytek Prime C2 Pro is an EDC (Every Day Carry) flashlight with a compact design, a convenient side button and a special matte finish already seen on other products from the same company. Prime C2 Pro has been updated maintaining the best features of the previous version with greater power, new button, new pole springs etc.
Prime C2 Pro is built in aeronautical aluminum with an anti-abrasive finish and has 2 modes of use: General and Advanced.
The version reviewed by me, with a warm tint, has a Cree sales package). It is rechargeable via a magnetic charger in the queue.
Prime C2 Pro has 12 brightness levels and a maximum battery life of 200 days (Firefly1).
It is IP68 certified (waterproof and dustproof) with a maximum immersion depth of 10 m for 2 hours.
MAIN FEATURES:
Color temperature: warm (Warm)
LED: Cree XHP50.2
Optics: TIR lens, transmits more lumens, provides a wide and comfortable beam with a spread of 120°
Light power, lumen: 2230 lm
Beam distance, meters: 121 m
Hot spot: Output: 70°:120°
Number of modes: 6 in standard mode and 12 in advanced mode
Battery compatibility: 1x18650 lithium ion
Possibility of using batteries with or without PCB
Battery status indication
Autonomy in maximum mode: 2 hours and 48 minutes (570 lm after 50 seconds)
Autonomy in minimum mode: 200 G
Strobe mode
Material: Aviation Aluminium
Anti-abrasive finish: Premium type III hard anodization 400 HV
Waterproof and dustproof standard: IP68 (10m for 2h)
Safe fall height: 10 m
Operating temperatures: -40 +40 °C
Protection from accidental ignition
Color battery status indication
Low battery level indication
Dimensions and weight
Head diameter: 25.4 mm
Body diameter: 20.5mm
Length: 117.7mm
Weight (without battery) 68 g
Weight (with battery) 118 g
Warranty and assistance
Armytek provides free repairs under warranty for 10 years (excluding batteries, chargers, switches and connectors, which have 2 years warranty) from the date of purchase if there is a document confirming the purchase. The warranty does not extend to damage caused by the user.
Immagine
Immagine
Armytek Prime C2 Pro arrived in a black cardboard box with the main features that distinguish it listed in detail, including the available levels.
Immagine
Inside the package we find:
Armytek Prime C2 Pro “Warm”, Armytek 18650 3500mAh rechargeable battery, Magnetic charging cable (proprietary), Holster, Steel clip, * Spare O-rings* and multilingual manual.
Immagine
The holster supplied with the torch is made of nylon, elasticated at the sides. It is simple but well made, quite soft with a hook and loop closure. At the back we find a D-ring at the top and a single loop in the center.
Immagine
The battery supplied with the Prime C2 Pro is a 3500mAh rechargeable 18650 flat surface battery.
The battery has a safety air intake and thermal protection.
Armytek Prime C2 Pro allows you to use any 18650 lithium ion battery, with PCB or without, Flat Top or Button Top, with 10A discharge current and provides complete protection against short circuit even in case of contact between magnetic connector and metal objects.
Immagine
Immagine
Armytek Prime C2 Pro is well built, has an excellent feel of robustness and holds well in the hand. Excellent grip even in rainy conditions thanks to the type of anodization (matt black); good dimensions and weight (118 mm for 118 g with battery).
Immagine
Immagine
The numerous writings on the torch are well made and understandable.
Immagine
On the head of the Prime C2 Pro we find a TIR optic protected by a tempered glass with anti-reflective coating with the Cree XHP50.2 LED in the warm version in the center. Thanks to the type of optics, the beam is wide with an output of 120°.
Immagine
Armytek Prime C2 Pro is equipped with a slightly crenulated satin steel bezel useful for protecting the optics and as personal defense.
Immagine
Immagine
The single button on the Prime C2 Pro is located on the side and is slightly protruding. Larger in size, with an audible and firm click, it works well in the dark even when wearing gloves. Below the button there is a notification LED. The raised shape of the button prevents the flashlight from rolling.
Immagine
Immagine
The central body of the Prime C2 Pro is smooth. On the body we find the space to insert the supplied clip which in my package appears to be of lower quality and different from the one depicted in the product advertising.
Immagine
The threads of the central tube are not anodized and arrive well lubricated. By slightly unscrewing the cap we obtain the mechanical lock of the torch. For water and dust protection we find a double O-ring. Armytek Prime C2 Pro is IP68 certified (10 meters submersible for 2 hours).
At the two poles, for contact with the battery, we find plated springs; the one on the tail cap is of moderate thickness. Armytek Prime C2 Pro has reverse polarity protection mechanism.
Immagine
At the base of the tail cap we find the proprietary magnetic charging base.
In the package we find the magnetic charging cable which allows fast and on-the-fly charging.
Immagine
To recharge the 18650 battery supplied with the flashlight, simply adhere the magnetic connector to the tail cap after slightly unscrewing the tail cap. It took me about 4 hours to fully recharge the 3500Mah battery.
COLOR INDICATION
Battery charger not connected:
• Green: The device is in standby mode.
Battery charger connected:
• Flashing green: Battery voltage rating.
• Flashing red: unscrew the rear cap 1/4 to refill.
• Flashing orange: the voltage of the USB power source is too low to be correct, continuation of charging or bad contact between the charger and the battery.
• Red: Charging is in progress with the rated charging current.
• Orange: USB power source voltage is too low, charging current may be reduced.
• Green: Charging is finished.
Immagine
The tail magnet has a fair amount of power and allows good anchoring of the Prime C2 Pro on ferrous materials.
Since the tail is flat it is possible to put the torch upright (candle-shaped).
Immagine
Armytek Prime C2 Pro near other flashlights.
Immagine
From left: Battery 18650, Nitecore MH15, Armytek Prime C2 Pro, Armytek Predator Pro, Speras E21 e Acebeam P16.
User Interface (UI)
Immagine
Armytek Prime C2 Pro has 6 or 12 levels depending on the usage mode chosen: General or Advanced. The Prime C2 Pro user interface is particular if we think of the 12 levels of the advanced mode but after a bit of practice it is truly complete and easy to remember.
To switch from one type of mode to another, unscrew the tail cap ¼ with the torch off, press the button and tighten the tail cap while holding the button down.
Levels available:
Turbo3: 2230 lm/2 h 48 min (570 lm after 30 sec)
Turbo2: 1590 lm/2 h 48 min (570 lm after 1 min 30 sec)
Turbo1: 760 lm/2 h 44 min (570 lm after 22 min)
Main3: 325 lm/5 h 20 min
Main2: 140 lm/12 h 30 min
Main1: 37 lm/40 h 30 min
Firefly3: 4.5 lm/12 d
Firefly2: 0.9 lm/40 d
Firefly1: 0.14 lm/200 d
Strobe3: 2230 lm/10 Hz/5 h 45 min (570 lm after 2 min)
Strobe2: 2230 lm/1 Hz/12 h (570 lm after 10 min)
Strobe1: 140lm/1Hz/55h
Immagine
Instructions taken from the Manual:
Before use: tighten the tail cap all the way.
GENERAL MODE
Modes: Firefly1, Firefly2, Main mode, Turbo mode (last used in Advanced, Turbo2 by default).
In the OFF state
1 click: to activate the last used mode.
Press and hold: To begin cycling through Firefly modes. Release for Select. Holding the button will begin to scroll through the Main modes.
In the ON state
1 click: to turn off the flashlight.
Press and hold: to begin cycling through Main modes from any mode. In the Firefly1 cycle through the main modes begins after the Firefly mode cycle. Release to select.
2 click: to activate Turbo mode from any mode. The second double-click restores the last used mode.
ADVANCED MODE
To switch from one type of operation to another, unscrew the tailcap by 1/4 with the torch off, press the button and tighten the tailcap while holding the button down.
Mode Sections:
[1] – Firefly Mode, [2] – Main Mode, [3] – Turbo Mode, [4] – Strobe Mode
In the OFF state:
Press and hold: to activate Firefly1 mode [Section 1]. Keeping the button pressed will start cycling through the modes: Firefly1 - Firefly2 - Firefly3 - Main1 - Main2 - Main3 - Turbo1.
In the ON state:
Press and hold: to start scrolling through the modes of the relevant section.
Same in OFF and ON states:
2 click: to activate Main mode [Section 2]. Another double-click to switch between the modes chosen in [Section 1] and [Section 2].
3 clicks: to activate Turbo mode [Section 3].
4 clicks: to activate Strobe mode [Section 4].
Auto memorization.
After switching off, the last mode used is stored for quick access the next time it is switched on.
Active temperature control.
When the temperature of the flashlight approaches +58 °С, the brightness decreases to a safe value, allowing the flashlight to avoid overheating for a long period of time. Under good air-cooled conditions, the flashlight provides light without losing power.
The warning indication shows the battery level and temperature inside the flashlight.
Low battery level. When the battery level is approximately <25%, the color LED will show the warning level by flashing orange once every 2 seconds.
With further voltage reduction, the brightness will begin to gradually decrease for the safety of the battery and the user. If the brightness of the mode (except Firefly Mode and Main1) is approximately <25% of the nominal value, the main LED will flash 2 times. Critical battery level approximately <10% is indicated by flashing red once per second.
High temperature.
When the temperature increases to the warning level, the colored LED flashes orange 3 times once every 2 seconds. In critical level it flashes red 3 times once in 1 second. The brightness starts to reduce to a safe level.
Lock function.
Unscrew the tail cap 1/4 to protect against accidental ignition. The status indication will be deactivated.
Multicolor status indication.
Short flashes every 4 seconds show battery level even in the OFF state (until the battery level becomes below critical). The indication also helps you find the flashlight in the dark.
Warnings:
For stable operation of the flashlight we recommend the brand 18650 Lithium ion batteries no longer than 70 mm with a current discharge of at least 10 A.
Immagine
BEAM and RUNTIME
Armytek Prime C2 Pro has a nice color in my warm version with a wide but balanced beam with 120° beam coverage. I didn’t notice PWM at first sight.
Immagine
Immagine
From the tests carried out with the OPPLE Light Master Pro, two meters away from the sensor, the value of the CCT color temperature and the Ra color rendering varies, as we have already seen, depending on the selected light level. Taking an average I get a CCT color temperature of around 4100 and a Ra of around 72.
In TURBO2 (1590 lumens) the measured CCT value is 4173 while the Ra is 72.2 - the Duv is excellent with a value of 0.0004.
Immagine
Immagine
With a thermal imager I detected how the heat is distributed in the Prime C2 Pro in Turbo2 mode (1590 lumens) 1 minute, 3 and 5 minutes after turning it on. With this brightness Prime C2 Pro quickly reaches high temperatures. As the minutes pass, the heat is also distributed towards the body and tail.
Immagine
Runtime:
Immagine
The runtime tests were done with the three Turbo modes (Turbo1, Turbo2 and Turbo3) and with the Main3 mode of 325 lumens in a closed environment with a temperature of approximately 21°C with the battery in supplied, a fully charged 3500mAh Armytek 18650. Prime C2 Pro when used on the Turbo overheats quickly; for electronics and LED protection Prime C2 Pro has an active real-time temperature control system to prevent overheating above +58 °C by adjusting the power when necessary.
I would like to point out that the values expressed by the graphs must be taken, above all, as a reference because they were made with means and environmental conditions different from those used in the laboratory.
In my tests the runtimes are slightly lower than those declared by the parent company.
Turbo1 (760lm). In Turbo1 mode the brightness starts at about a third of the brightest mode (Turbo3). The trend is constant for about 2 hours after switching on and then the drops begin due to battery exhaustion.
Turbo2 (1590lm). In Turbo2 the brightness starts at about two thirds of the brightest mode (Turbo3). After about 3 minutes there is a decrease which brings the light output to the lowest turbo level (Turbo1) in about ten minutes. After just over 100 minutes, towards the end of the battery, there are further drops in brightness.
Turbo3 (2230lm). After about 1 minute from switching on there is a sudden drop in brightness which settles at a lower value than that of the Turbo1 for about 150 minutes. This test has different values from those declared by the parent company and was repeated by me twice.
Main3 (325lm). In main3 with this brightness there is a constant trend for almost 5 hours before the battery runs out.
N.B. In all the tests I have carried out Armytek Prime C2 Pro, once the battery charge is finished, it does not turn off but remains in Firefly mode for a few hours.
Immagine
The first 20 minutes
Immagine
VIDEO Unboxing
CONCLUSIONS
Armytek Prime C2 Pro was a pleasant surprise.
I particularly appreciated the flexibility in the choice of lighting levels which, being twelve, make it easy to use the most necessary one, and in the compatibility with batteries from other brands and not proprietary ones.
I also appreciated the color of the light beam and the magnetic base, always useful for a functional and reasonably powerful EDC torch like the Prime C2 Pro.
Finally, the package is complete with holster and “on the fly” rechargeable battery via a cable with magnetic connector.
Recommended.
Roberto
------ My YOUTUBE CHANNEL ------------------------------------------------
Thank for review. I have older version and main problem for me is that pocket clip and it looks it is still nearly the same.
I’ve been using mine for roughly a year, with the non-magnetic tailcap to shave a few mm / grams.
Mine has a nice green AR coating, and the Duv is pleasant on most levels, even rosy in the turbos.
This is one of my favorite lights, mostly because the beaded TIR and floody beam. I do wish they would do a Nichia 144A version of it to match the Wizard C2 Nichia.
I can not find anything to complain about, which is saying something.
Yes, the clip is short, I don’t use it, I prefer the holster.
Yes, with Nichia it would be nice. Let’s hope in the future.
It’s one of three lights I’m using for walking the dog, and it’s certainly the best one, despite being low CRI. You just don’t notice this at its 4000K and its beautiful duv. The rendering is just great.
Aren’t that two independent stores?
Thanks for the observation, maybe you’re right. However I corrected it.
Hello, can you compare it with olight baton 3 pro?
I’m sorry but I don’t have the Olight Baton 3 Pro.
thank you, but looking at the runtime specifications… I can get the olight for 20€ less than the prime c2 pro so I’m wondering
