Okay, so this isn’t an exact fit for this forum, but y’all seem extremely knowledgeable and it is at least semi related as what I’m trying to do is basically a really big flashlight. I am looking to build about 40 home brewed pin spots for stage use, as nothing seems to exist in the niche I’m looking to fill commercially that works the way I need it to. I am essentially looking to use the brightest possible RGBW LED I can find, in the tightest beam I can get. Size is not really a MAJOR concern, but ideally I’d like to keep it under the size of a pringles can or so. My problem… there do not seem to be any off the shelf optics that I can find with my limited experience that A) fit this module and B) are tight enough to function as a pin spot. If you know of a brighter/alternative module, I am all ears, especially if it has an off the shelf optic available. I have emailed around to all the various consumer facing TIR optics manufacturers I can dig up, but from the specs on this thing it just doesn’t seem like anything fits on it, and on the seldom chance that someone has something that fits, it’s a wider angle than works for me. I’m shooting for <10 degrees. If that’s just unrealistic, let me know and I’ll probably just have to abandon the project but it seems like there should be something somewhere that does what I want. Even just some help in translating the physical specs of this thing so I know what I am looking for to be compatible would be fantastic.
Thanks for your time!
