As the night came, I rushed to see the beautiful Aux LEDs doing their magic. To my disappointement, after enabling the Aux lights by clicking 7 times, instead of the nice mix of different colours, I could only see the green LEDs and a bit of the purple ones.
So I unscrewed the lens and had a go at the trimmers, after which it looks this (managed to get the blue lights on).
Now to my questions:
- does anyone know which trimmer is responsible for what and which direction increases/decreases intensity? After rotating them for a bit, I wasn’t sure what they were supposed to do.
apart from the 3 colours you see in the picture (green, purple and blue), were there supposed to be more colours?
When i adjusted mine, i just put aux lights setting on HIGH (7H clicks) and adjusted as necessary. with a fully charged battery i was able to see what each dial changed. I just used the smallest eyeglass flathead screwdriver i had. Hope this helps. I don’t remember which dial adjust what color. I think those are the only colors though - blue, green ,purple.
I somehow managed to make it brighter, now the purple is the brightest, followed by the blue LEDs. Green can barely be seen.
I am not sure how I changed the intensity, does 7H mean 7 clicks and holding the 7th click?
The whole MF01 series including the Mini has the same AUX system afaik.
4 colours. Always in voltage mode, meaning the different AUX leds activate depending on current voltage of the battery. There is no way to switch colours or have only one colour active at all times.
Available options from the Anduril config are off, low, high, blinking.
Full battery - green purple blue.
Medium - purple blue
low - red puple blue
time to freaking charge boss - red only
Opening the bezel, removing glass and optic and you have access to the board, leds and pots. Use a small phillips screwdriver to turn the pots. There should be four of them, one for each colour.
Obviously on a full battery you can only adjust green, purple, blue by sight. If you want to adjust red, you need to insert a battery at low capacity. The Astrolux/Mateminco engineers didn’t use the resistors which Lexel originally recommend for the design, so right now turning the pots in the beginning will only very slowly change the brightness of the AUX. The last bit of rotation before reaching max will go off like crazy though, so rotate very carefully and slowly in the end.
