Fast tap about 15 times untill light stops to come out, then fast turn on the light, and I have two times 2x blink, and I turn off the light after second 2x blink in order to select Group 2: low, med, high, turbo…
But nothing, I get back to Moon-Turbo-Tactical Strobe-Battcheck-Bike Flasher…
Can anyone help I want to select Group 2 : low, med, high, turbo with mode memory on forward click switch… ?
Ok, for mode memory I understand and I managed to choose that, but for group mode I’m still not clear there are only 1x double click for group mode, how to choose between 4 and 7 modes, I can not understand that
Group Mode programming
When the light is on
Fast click 15+ times or until the light turns off
blink-click-blink
Memory Mode programming
blink-blink-(wait for the 2nd double blink)-blink-click-blink
You must enter programming mode twice. It cannot be done in one go.
First of all on fwd clicky switches light can’t be on.
So you must do 15+ half press times tap when light is off then when light stop to come out you must fast push a switch to the end to turn on the light and then you have that two times 2x blinks.
I do first time when see your post on first time 2x blink, blink-click-blink and nothing… Then I do for mode memory and that works fine. But when I do first 2x blink, blink-click-blink nothing is happens…
So I have now mode memory on Moon-Turbo-Tactical Strobe-Battcheck-Bike Flasher, but can’t change to other groups. If someone use this driver with fwd click switch a help will be appreciated.
