ok guys i need help
i bought a Astrolux SS and a Astrolux S2 from bg
now the S2 is great (apart from missing screws to hold the led down :person_facepalming: ) , but the SS Stainless Steel has a problem where it powers down unless i have it on the highest setting
now bg (after alot of to and fro emails) is sending me another driver board
so what’s this thread about ?
well it was going to be about what the heck do i use to remove the Brass 21.6mm Ring that holds the driver board in (i used a pair of needle nosed pliers in the end, but dam it was in tight)
anyway according to bg the driver boards are the same, but i would like someone who knows about the lights to tell me if this solder joint is meant to be here between pins 6 and 7 of the ATtiny25 chip on the stainless steel light
this is the picture from the Astrolux S2 ,
and as you can see their isn’t a solder joint between pin 6 and 7
so did the factory make a boo boo ? or is the link their to provide extra power or something else?
edit after looking at this thread before posting, i’ve noticed a few differences between the boards, it might just be cosmetic
but i know some of you might know what they are
any advice is appreciated
