ASTROLUX® 2024 Collection & Discussion >>> FT06, EA09, CL03, FT05, EC01X, EC07, ED01, LT2, and More...
ASTROLUX® EA09 10360lm 460m single 211500/ 26650/ 21700/ 18650 Flashlight
ASTROLUX® CL03 450lm 460m Telescopic Camping Light
ASTROLUX® FT05 3050lm 711m 26980 Flashlight
ASTROLUX® EC01X SBT90.2 6800lm 46950 Flashlight
Product Name: ASTROLUX EC01X
Brand: ASTROLUX
Model: EC01X
LED Type: LUMINUS SBT90.2
Color Temperature: CW
Battery Configuration(s): 1x46950
Range: 3065m
Peak Beam Intensity: 2350000cd
Lumens: 6800lm
Mode: Stepless Dimming/ TURBO/ STROBE/ Voltage Checker
Output: 0.3%(Moonlight); 1%-70%(Ramping); 100%(Turbo)
Runtime: Unspecified
Driver Type: Buck Constant Current Driver
Firmware: Stock
Voltage Input: 4.2V
Built-in charger: Yes, USB-C fast rechargeable
Lens: Tempered Glass
Reflector: Aluminium reflector
Switch Type: Electronic Switch
Switch Location: Side
Tail Stand: Yes
Material: Aluminium
Impact Resistant: 1m
Waterproof: IPX6
Color: Black/ Green
Weight: 918G with 46950 body tube
ASTROLUX® EC07 HP50(6500K+3000K) 13000lm +Red Laser(650nm) 32700 PD3 Rechargeable Battery
Product:
Astrolux EC07
Material: Aluminum Alloy
LED: HP50(6500K+3000K)+Red Laser(650nm)
Tailcap: Magnetical Tailcap
Driver: Linear Direct Drive+Constant Current
Lumens: 130001m(6500K+3000K)
Intensity: 54650cd
Max Distance: 468 meters
Waterproof: IP68
Impact Resistance: 1m
Weight: approximately 212g (without battery)
Size: 117.1mm56mm40mm (lengthhead diameterbody diameter)
Battery: One 32700 battery. High drain unprotected battery is recommended. Cell is included.
Brand: ASTROLUX
Group Buy Price: $19.99 (usual $24.99) | More details
Model: ED01
Material: Aluminium Alloy
LED: Luminleds HL2X LED
Driver: Linear Direct Drive Driver
Lumens: 1287lm
Intensity: 50850cd
Max Distance: 451 meters
Waterproof: IPX6
Weight: approximately 75g (without battery)
Size: 117.7mm26.8mm25.3mm (lengthhead diameterbody diameter)
Battery: One 18650 or 18350 battery. High drain unprotected battery is recommended. Cell is not included.
ASTROLUX® EA04 4*HP50 (NOT CREE) 12600lm Flashlight
FEATURES:
  1. Design inspiration of Astrolux EA04 comes from professional flashlight forums which is more durable, more powerful, and more functional.
  2. High efficiency enables maximum output up to 12600 lumens
  3. Driven by one 18650/21700/26650/26350 battery, usual and EDC as you like.
  4. Brightness modes include both stepless dimming and mode dimming.
  5. Toughened ultra-clear mineral glass with anti-reflective coating
  6. Constructed from aerospace grade aluminum alloy
  7. HAIII military grade hard-anodized
  8. Waterproof in accordance with IPX6
  9. Impact resistant to 1 meters
  10. Tail stand capability
SPECIFICATIONS:
Brand Astrolux
Model EA04
Lumen 12,600LM
Beam intensity 382M
Peak Beam Intensity 36481CD
Firmware Direct drive FET driver
Battery 1 x 18650/21700/26650/26350 battery (Not included)
High-drain unprotected battery is recommended|
|Charge|USB-C fast rechargeable|
|Waterproof|IPX6|
|Impact resistance|1m|
|Size|with 26650 body tube: 170g excludes battery|
|Weight|26650 body tube: 1164136mm (Length* Head diameter* Body diameter)|
ASTROLUX BC6 6* LEDs 2000lm Bike Headlamp
Brand Astrolux
Mode BC6
LED 6
Lumens 2000Lm
Light Range 300-meter max
Mode 5, Low–Medium–High–Strobe–SOS
Battery 4800mAh
Battery Life >6h
Charging time 2h
Charging Type Type-C
Waterproof level IPX6
Net Weight 200g
Total Weight 250g
Product Size 80mm x 80mm x 50mm
7 Thanks
Reserved.
Reserved 2.
Reserved
It’s gotten hard to support Astrolux any more with their lack of support but those sound like cool lights.
I’ve been looking for a nice new 14500 light… not sure what throw/flood means though. I hope it’s not a zoomie.
Good news!
I’m curious if Mateminco or Sofirn will produce these flashlights.
I’m still hoping for an Astrolux MF03 or a similar flashlight with a few XHP70.
Need to sell more small lights to make the business profitable again first. :sweat_smile:
ASTROLUX EA04 (2023)
4*HP50 12600lm 382m 26650/ 26350/ 18650/ 21700
DD Driver / Simpe Mateminco UI
I like that. I’d buy it.
My guess is this is Astroluxes’ version of the Mateminco LT40 i just reviewed. That UI is…forgettable. really needs Anduril 2, or I hope Astrolux fixed the thermal issue.
Could be the same as LT40 but I have to check if the LED model is still CREE or something else.
The LT40 came only with xhp50B. Maybe they’ll use other LEDs?
Any plans for anduril lights?
Hmmm, the EA04 looks like an updated EA01S, with (possibly) slightly higher max output and a simple UI (in stead of Anduril).
I already have an EA01S and I like Anduril, so I don’t see much interesting changes/improvements in why I should want a EA04, or am I missing something?!?
Price will be lower than EA01S (current rate).
ASTROLUX hasn’t been using Anduril firmware for quite some time.
If it’s the same as the LT40, and Astrolux hasn’t changed the thermal algorithm from the Mateminco version, then it will not be an upgrade to the EA01S which has Anduril and can be tweaked for better performance and slower stepdown. The LT40 only has smooth ramping, not stepped.
FEATURES:
  6. Constructed from aerospace grade aluminium alloy
SPECIFICATIONS:
Brand Astrolux
Model EA04
Lumen 12,600LM
Beam intensity 382M
|Waterproof|IPX6|
3 categories of lights are:
  1. Mixed tint multi-emitter 26650/ 21700
  2. P60 style 18650
  3. Throw-flood 14500
All lights are still in testing phase, so I won’t publish any image for now.
If you still support ASTROLUX, be sure to bookmark this thread for more updates in early June.
A rebadged Mateminco LT40 in a ancy new color suit.
