Bad Gateway error
Has anyone else discovered random „bad gateway“ errors while posting something or opening any BLF links?
Yup! Some in the last minutes.
But I managed to access after a while.
Okay, good to know. I was already afraid it might be a DNS network issue with my Pi-Hole. It seems it is occurring very often in the past 5 minutes (9 pm CEST). Performance seems to be affected as well as I noticed quite some lags when searching for a keyword.
Same here actually. Not sure yet where the problem is, I’ll keep you posted.
me too
Bad gateway sounds like it’s coming from the TLS proxy.
I’m still trying to wrap my head around this new setup, the SSL frontend load balancer is technically a reverse proxy, so I think the bad gateway error would be when the SSL frontend can’t forward its request to the backend server that we’re running on?
Yes, that’s what I assume as well. Maybe timeout, too much concurrent requests, something like that. Are there any logs for the load balancer? Otherwise you might have to contact the hosting provider.
I would tend to suspect the problem is on my end then, since the frontend is alive and trying to forward requests, but the receiving end that runs this website is not responding for whatever reason. I’ll have to dig into the logs as you mention.
Let’s continue this discussion in the other thread, as it’s related to the new SSL setup.
