I have a pretty extensive FAK, it takes up two large backpacks and includes everything needed to take care of most emergencies up to and including sutures and minor surgeries.
One piece of equipment I'm looking to add is a pulse oximetry (SPO2). I don't usually buy cheap stuff since one day me/my families lives could literally depend on this stuff but I'm thinking a SPO2 meter isn't a critical piece of equipment. Mostly I need one that has the lowest stand-by current, since 99.9999% of the time it'll just be sitting in a bag but of course accuracy is important as well. Anyone have any experience with any of the battery powered / built in display / stand-alone units.
This is is the BG one I'm specifically asking about but feel free to recommend any brand from any seller, price range as cheap as possible is preferred but <$100 max.
During the treatment / triage of anyone I come across requiring immediate medical attention for the ~10 minutes it takes a squad to get there. I imagine it would be especially useful should I ever run into anyone having chest pains / a heart attack / thinking they were having a heart attack.
I’m not planning on any sort of EOTW situation or anything crazy like that, this is my day to day FAK, it goes where we [my family] goes- outdoor activities, day trips, vacation, horse shows / events.
I’ve used it many times, most recently I used my neck brace to immobilize a little girl’s next after a fall from a horse at a riding event which was so far it it took the EMT’s 25 minutes to get there. Most of the time it’s just band-aid’s or minor stuff.
Interesting, how does this help recognize heart attack? from irregularities in the pulse waveform?
I have been thinking about getting something like this to be able to check saturation, but never noticed that some of these draw graphs too.
1st a working concept:
These do NOT measure the blood oxygen directly. They use color spectrometry and density to determine pulse and interpret the O2 level.
Oxygenated blood is ‘redder’ than de-oxygenated blood. The light bands used to measure this through the finger are very specific. They then use this to interpret the O2 level. It’s really measuring color, red color.
[note-carbon monoxide inhalation creates carboxy-hemoglobin which is VERY red. This makes an oximeter useless for figuring out saturation in this kind of case. The molecule is also very tenacious when it binds to hemoglobin rendering it useless for carrying O2. This is why carbon monoxide inhalation is so bad.]
[note 2 - smokers tend to have ~ 10-15% carbon monoxide load after smoking. They often want to use an oximeter to figure out if they have screwed up their lungs….yet. If a smoker shows a significant drop in O2, they are REALLY screwed up. Most do not until they are pretty far gone. Their is NO getting away with smoking. It’s not if damage, it’s how much damage and when.]
As the heart beats the blood moves into the finger capillaries as they expand a tad, then relax back down. This changes the color intensity. This is how it tracks the pulse. A very important piece is tracking the quality of the pulse signal. If the hand is too cold so that it is vasoconstricted (or other circulatory problem) the signal is poor and the readout is not to be trusted. Lots of people don’t know or understand that concept. It is critical.
You can imagine the signal sensitivity that is necessary to pickup up color intensity changes at the finger tip from heart beat pressure changes.
Pretty much anything above 90% in normal people doing OK is fine. Normal reading are around 95-97. You cannot reach 100 without breathing pure O2. Normal people not at altitude (or other problem) do not get short of breath by O2 deprivation. SOB generally comes from CO2 increases. BREATHING is far more about getting CO2 OUT, than O2 in.
If you could hold your breath for 3 minutes you would be wanting to breath in 30 seconds because of CO2 increase but your O2 sats don’t decline much unit the 3” mark. People that are showing true sats below 85% are potentially serious trouble. By then you are going into respiratory failure. The body is serious about getting rid of CO2 until something prevents it. If it cannot bad things happen fast.
Note on heart attack: I think it’s evident if there is not pulse > the saturation will be horrible. Depending on the waveform produced on some models you ‘may’ be able to make an interpretation of what is going on but more likely not. If there is a coronary obstruction not causing a full on failure that can be localized to the heart, so the saturation in the rest of the body may not be abnormal at all.
The heart, brain and kidney ‘strip’ almost ALL of the O2 out of the blood going through. This makes these organs hypersensitive to even short term deprivations in O2 or circulation. In the rest of the (resting) body as much as 60-80% of the O2 will pass through unused.
i think we trust chinese sellers too much on BLF, we know the flashlight business but everything else is much more complicated, the likelihood of this device being accurate enough to work is about the same as food from china not having lead or another banned chemical
the chinese don’t trust chinese made products, they buy imported merchandise
Absolutely! These need to be precision instruments. I’ve seen lots that were not any good at all. I can’t vouch for or condemn that particular unit but I would never trust it until I verified it against a known good clinical unit. Most people will not have the ability to do that. You can’t take your DVM or Fluke to it to test it.
