Basic Charger - LiitoKala Lii-S2 vs Vapcell U2
Hi all,
I’m placing an order to Convoy and I want to take the chanche to buy my first charger. (until now I always used internal charger on my flashlights).
I don’t need anything more than basic functionality.
I’ve seen LiitoKala Lii-S2 and Vapcell U2 are similarly priced and, from what I can understand as a newbie, have similar specs.
Is there any reason to choose one over the other?
Thanks
Apart from the low draw F15 batteries I’m avoiding everything from Vapcell. Both chargers and batteries are dangerous.
Wow…thanks for the info!
For me safety come first!
I think I will invest some few bucks more and get an XTAR VX2 Pro…I don’t want to risk on this kind of things.
My Vapcell U2 has so far not caught fire.
Same, granted when I’m using it I’m always in the same room and would never charge when I’m not a home. Ever since I had an H10 heat up and nearly burn me as I was sleeping on the couch, I no longer trust anything to do with batteries!
I don’t have any experience with either charger that you ask about. But just a counterpoint about Vapcell. I have something like 50 LiIon cells with their brand on them. I have got them over the last three years. I have had zero problems with any of them. Actually they perform very close to their specifications.
I also have an S4+ that I have had for a few years. It gets used regularly for 14500 cells and NiMh cells. (sometimes it is just easier than changing the program on the MC3000 or S8000 chargers), Anyway, I have had zero problems with the S4+. All of that is not meant to mean that I think all of their products are flawless. But I also don’t think that they are so bad that they should be avoided at all cost. Nor, more than any other cell or charger, worry you about things blowing up or catching fire.
HKJ reviewed that model and his conclusion was “it is fairly good” If you can spend a few more dollars and don’t insist on USB power, there are better.
