Hi,
I have been a long time flashaholic but have done very little modding. I have some basic understanding of electronics and am pretty handy but there are still some small things I am confused about. I want to do a few triple builds off a Convoy S2+ host, 18350’s probably, Nichia 219C and a version using Samsung high CRI’s, Dragon/H17F/Moonlight driver.
I hope the community here can help me. Here goes!
- When a driver lists an output current as 3A is that split across the three emitters, or is it per emitter? I assume per, so in a triple Nichia 219C build, each LED would get 3 amps at 100% right?
- Why is 3A the sweet spot for many drivers (ie Moonlight Special, Dr. Jones H17F)? I know that LED’s are more efficient at lower currents but 3A, the 219C gets something like 800 lumens right? Ok, why not 4A for 950 lumens? I realize that more current means more heat but how was it decided that 3A is the sweet spot? 2400 lumens at 3A is plenty for me but I am trying to decide how one decides what the “right” current is. I am mostly asking this question to figure out if I should stack extra 7135’s on the Moonlight driver to get higher output.
- I’ve found output charts but are there perhaps runtime charts for different emitters at different outputs? Maybe that is a determining factor related to Question 2. In other words, how long do you want to run a flashlight on high.
- Any advice on how to best drive Samsung LH351D’s? They look like they put out more lumens than 219C’s at the same current but also require a higher voltage.
Thanks for your help!
