Battery pack
Has anyone had ago at making a battery pack ? i need some way of running my hotwire mod and since no one seems to be making decent 6aa to 2d adaptors any more i thought i’d have ago a making a battery pack.
I know basically how to make it but what do you use to keep the batteries together?
cheers
Charles
In dons tradition, duct tape and lolly sticks :slight_smile:
The easiest way for you to do it would be to go to a place like Batteries + or anywhere that builds laptop battery packs. Then try to talk them into spotwelding some tabs onto your batteries. Once that is done you can fairly easily solder wire onto the tabs and wire it however it is needed. (With balancing taps if needed)
Once you are done with that just wrap it in electrical tape to hold it all together.
cheers for that, i’ll have to find someone in the uk that makes them.
wouldn’t it be easier just to solder some tabs on?
Why not use generce 3AA holders and mod them to fit? Its usually only a few mm plastic in the way.
Soldering tabs to LiIon cells is not trivial. You can ruin the cells pretty fast without noticing. I dont know about NiMH cells though.
Soldering to the cells themselves can be challenging, I have done it before though. The key is a high wattage iron and to only apply heat for a very short amount of time. After that you need to cool it down.
I recall reading somewhere it was feasible to use the ’“Solder-It” Silver Bearing paste to solder tabs with less risk of overheating the battery, I have not tried it but have had it in the back of my mind. I even bought some at Princess Auto and it still sits in my tool box.
I have a 100 watt iron so i guess that will work :slight_smile: and i’m using NIMH cells btw…
