battery voltage checker/alarm for single cell
Hi: I used to have 3 or 4 battery checkers with alarm when I used to run my 1/8 scale Mugen buggy on 4s lipo’s. Any way these can be modified to check a single cell 18650? This is a link just to show what I am talking about here:http://www.ebay.com/itm/1S-6S-Low-Voltage-Buzzer-Alarm-LED-Lipo-Battery-Voltage-Indicator-Checker-Tester-/180848891577?pt=Radio_Control_Parts_Accessories&hash=item2a1b6f16b9#ht_4567wt_1102. Thanks HB
Solder some wires to the first 2 pins of the checker so you can reach each end of the 18650. Or better yet solder the first 2 pins to a battery case like this -
IIRC the first pin is on the left but don’t quote me.
Thanks for fixing! HB
Thanks….I have one of those holders just sitting around. HB
I think you are correct “-” is far left,I guess the one next to it is “+” according to this pic:http://learn.trossenrobotics.com/images/tutorials/lipo/batteryTester1.jpg……I hope it came out this time?! Thanks,HB
Yes the first pin is ground only “-”. All the other pins connect to the positive of each cell (if more than one is connected).
Any recommendations on a cheap case to mount that in?
Sorry, I don’t have any recommendations for a case. As an option you could use a stiff bit of plastic as a base and mount both the checker and cell carrier on it, that would save the wires from fatiguing.
I ordered a couple. I’ll use one to check lipo’s and the other to monitor battery charge in a motorbike. I only need to find a cheap case to mount it in.
These holders with protection are crap for applications which don’t get charged.
The protection needs always be reseted through an external power source.
Is the ebay one really containing a buzzer? It looks just like a voltmeter…?
I like this case most. I have used it for several DIY projects. The springs can be shortened to accept protected cells with ease, the small compartment in the top can be used to store electronics.
The one linked in the OP looks like it doesn’t have a buzzer to me. The ones with buzzers look like this -
http://blueskyrc.com/index.php?main_page=product_info&products_id=71
As I understand OP just wants to quick check battery voltage. (I’m guessing he doesn’t have a multimeter)
It checks from 1 to 6 cells
Starting from left pin
gnd …1st….2nd……3rd….4th……5th……6th
One from link doesn’t have buzzer…this one does
http://www.ebay.com/itm/RC-1S-8S-Lipo-Battery-LED-Voltage-Indicator-Tester-Low-Voltage-Alarm-Buzzer/331147114038?\_trksid=p2047675.c100009.m1982&\_trkparms=aid%3D333001%26algo%3DRIC.FIT%26ao%3D1%26asc%3D20466%26meid%3D5313662734770555189%26pid%3D100009%26prg%3D9138%26rk%3D1%26rkt%3D10%26sd%3D180848891577
Interesting. How to integrate into existing charger?
Alarm version
Ouch. Inaccurate after all.
They are not designed to be used with chargers (they don’t balance cells), nor are they designed to be overly accurate. The are designed for rc lipo batteries which are unprotected. The theory is the main leads of the lipo are plugged into the rc whilst the balance tap is plugged into this device. When the cells get to low voltage the alarm sounds (if fitted with a buzzer otherwise they are purely a voltage checker and inaccurate at that). Problem with the alarm is it is usually not loud enough to be heard over the rc. Most electronic speed controllers have a low voltage cut off built in nowadays anyway so these things are pretty obsolete (or they should be IMO).
freeme if you are looking for something to use with a charger look up stand alone balancers. They are used for lipo packs (of more than 1 cell in series) that are charged through the main leads. The stand alone balancer plugs into the balance tap and drains the higher voltage cells until they are all even. Also an outdated way of charging IMO. Most hobby chargers have built in balance ports.
Depending on the quality of the device there can be inaccuracies in both the stand alone balancer and the balance charger.
There are simple balance chargers that charge only through the balance tap. They are usually reasonable for the price. I have a hobby charger that charges only through the balance tap but up to 8 amps individually for each cell.
Sorry, got a little of topic.
I have a DMM,just thought this would be more handy?! Thanks,HB
Thank you pinkpanda3310 for your detail explanation. i am not from world of RC. Therefore, i am unfamilar with hobby chargers, Lipos and their complicated charging methods. Nevertheless, the topic is still intriguing and will definitely find out more when i am free.
I actually thought of giving it Volt tester to my clients, as i believe most end-users do not own a DMM. It will be useful for them to perform checks by themselves. That is why the unit has to be of decent accuracy. 0.01V is good enough but hope it really perform as stated. Think I will order one to test out first.
I’m not sure I understand why it needs to be such high accuracy. Of course, in rc there is a lot of voltage droop because of high currents but even for flashlights it’s really just to get an idea of how full/empty the cell is. Whether a cell reads 3.5v or 3.7v to me it’s flat and needs charging.
