This flashlight has been in my wishlist since i`ve heard that Wurkkos would release it. I really wanted to compare Fc12 with the three times more expensive Fenix PD35v3, which has the same form factor and LED.
Fc12 has a lot of attractive features:Type-C charging, convenient UI, good brightess and awesome throw. All that, almost any user would like to get. All this for really affordable price.
The question is that Sofirn (aka Wurkkos) are are mastesrs in spoling potentially flawless model. Lets take a look if they managed to screw up again.
➤ AMAZON
STATED SPECIFICATIONS
LED: 1x Luminus SFT-40
Working voltage: 2.7V - 4.2V
Batteries: 1x 18650 Li-ion battery
Dimensions: 136.5mm (length) × 24mm (diameter)
Weight: 85 grams (without battery)
Flashlight body: aerospace grade 6061 aluminum alloy, CNC hard anodizing according to military grade III specification, anti-abrasive coating for a durable body, anti-collision geometry and better heat transfer.
Tempered Mineral Glass Lenses
Water resistant iIPX-8 (up to 2 meters underwater, not for diving)
Mode Memory: Remembers the last brightness level used in common modes (ECO / Low / Med / High)
Preset brightness levels and stepless brightness control
Reverse polarity protection
Low voltage warning by flashing side button
Low voltage protection: The flashlight will automatically shut off when the voltage is below 3.0V. It will also shut off automatically if the voltage gets too low.
Advanced Temperature Control (ATR) technology: When the temperature rises, the FC12 is programmed to automatically dim and brighten to prevent overheating.
PACKAGE AND APPEARANCE
The usual yellow and white cardboard for Wurkkos. Not frankly cheap, but not sort of a good for gift thing. The price class is immediately visible …
Kit includes absolutely all you need: flashlight, 3000mah 18650 battery, type-C charging cable, lanyard, o-rings, manual. There is only no holster, but you should not expect to get with a kit that cheap.
The length of the Wurkkos FC12 is quite large. 136.5 mm is already the very edge of the EDC segment. But this is a fairly common size for a two-buttons model.
As you can see, I got a version in an unusual color. It reminds me of the plastic monster figures I used to play when was a kid in the early 90s. I’m sure many of your had such onse.
Optionally, you can choose classic black and some other colors.
Sofirn usually doesn’t bother with the design of their models, but their sub-brand Wurrkos pays attention to this. So it is here, despite playing in the budget league, FC12 looks quite good. Just imagine the body in black, it would definitely be recognizable here and would not get lost against the background of flashlights by some large expensive brands.
There is a usual direct click power button in the tailcap. Deep move, tangible click.
The flashlight can be disassembled into three parts.
The thread is normally lubricated
There are quite thick springs at both sides.
Unlike similar size big brands models, FC12 lets you use flat-top batteries. Spring at head also helps to withstand gun recoil if you decide to gun mount flashlight.
The knurling is unusual, reminded me of a sturgeon. It is undoubtedly tenacious even when clip is detached.
The head is long, with symbolic cooling fins
The button is convenient and easy to find.
There is a traditional red-green indicator light.
A Type-C charge connector is covered with a thick plug.
Having got used to 2-3A in 21700 models, it is somehow difficult to say “yes, good” when see 1A charging. But, nevertheless, this is a completely normal current for 18650 flashlights, it can charge almost any battery in + –3 hours.
The reflector is small, quite typical in size for an EDC model. At the bottom of the smooth reflector is an interesting, good combination of brightness and range, Luminus SFT40 LED.
So far so good. Awesome design and visible build quality for its price.The flashlight has a good recognizable appearance, a convenient button and a good reliable grip.
UI
Oh, it’s okay here too. It is very, very pleasing that the manufacturer thought about both for the ordinary user, who gets classic UI with preset modes, and for the advanced user, who will enjoy the smooth adjustment brightness.
TB - tail button
SB - side button
There is modes memory.
Switching between the two types of control - 4 clicks of the SB from ON.
If the flashlight is turned off after clicking TB, then the SB is inactive, the circuit is open.
Preset modes
well, this is just classic-classic
On / off - TB
Switching modes in ascending order (Eco-Lo-Med-Hi) - click SB
Turbo - 2x SB clicks
Stroboscope - 3x clicks SB (switching between them - 2x clicks)
Stepless(ramping) model.
On / off - TB
Brightness control - holding SB
HOW WURKKOS FC12 ILLUMINATES
Like i said in the very beginning, Sofirn \ Wurrkos managed to screw up with a perfect model.
Ok, is no stabilization and I’m ready to say “nevermind” to this. But there is an agressive thermoregulation zigzags and I hate `em.
Again, there is the same size Fenix PD35 v3 with the same LED. PD35 v3 is really worse in any single feature besided stabilization - Fenix is normally stabilized up to a slightly less bright High. You can see my review of this flashlight if need.
I am sure, that the thermoregulation threshold needs to be raised - this should significantly improve the situation. A flashlight with a body of this size shouldn`t have problems with 800 lumens of High mode. I will push through this moment, if the manufacturer changes something, I will indicate in the review
But when it comes to light itself, everything is totally fine. Besides, of course, cold light from the SFT40 LED, there is simply no choice of color temperature for this LED. But there is choice of color tint.
And while $100 model of Fenix have the same LED with unbelievably green tint, $25 Wurkkos FC12 gives you pure clear cool white light without any parasitic tints.
And one more thing, as you can see SFT40 provides with an awesome throw even when installed in such a tiny reflector.
I would say that 200-250m is already a functional limit for SFT40, which is really, really good throw, considering an overall size of flashlight.
May be, maybe it will be possible to talk about 400m throw when you use flashlight in complete darkness to somehow highlight the general contours or catch glare from a distant white object. But,again, guys. This is a pocket EDC flashlight. What kind of 400m can we talk about here?
400m
OVERALL IMPRESSION
Frankly, I don’t understand how Sofirn manage to screw up model which is so potentially good. This is not the 1st time, and i bet not the last.
They released a really cool flashlight. Affordable, with convenient and reliable grip, with good UI (if two-buttons models are OK for you), with built-in charging, a range really long for such a shallow optics.
Jus what you would pick to give away to your Dad or a friend, saying. And also what an experienced user would use without getting pissed off.
But it turned out the same as with compact a long-range novelty - Sofirn IF22 (a), which I reviewed quite recently. For some unknown reason, the manufacturer decided that it was not worth making a flashlight that was absolutely wonderful for its price, and it was necessary to screw up a little so that the flashlight was just good. So they just decided to get rid of brightess stabilizaion and jump up and down on a roller coaster of active thermoregulation instead.
Well, result is good anyway. Good, even with all that i mentioned.
And an ordinary user is likely to be happy with FC12.
After all, I repeat, there is everything you would like to get from a flashlight in terms of brightness, range, and ease of use and charging.
Ah, close tange use, of course, will not be convenient. But in my experience of communicating with an ordinary users, they will always prefer some extra throw to the convenience of close range work.
You can just walk around with FC12 and be able to “whoa, take a look at thiiiis, yeah, this tree.” It will fit in your pocket and will not tear a hole in your wallet in any way. The price tag for a complete kit is absolutely affordable for any buyer.
By the way, yes, Wurrkos emphasize it`s tactical potential in the promo pictures. It is naive to consider a flashlight without an instant strobe and without an impact bezel as a tactical model.
But there is a comfortable, reliable grip, instant access to the turbo with a tail button (of course, if you turn off the flashlight in the turbo before that). And given the brightness and good focusing of light, the FC12 can still be viewed as a sort of low-end tactical model. If you want to blind your opponent at a low cost - yes, FC12 will handle it.
But for most of the aforementioned experienced users, I am sure that the zigzags on the graph of higher brightness will become deal killer.
However, there is the Sofirn SP35 for such buyers or even rather Wurkkos TS21. I think the 18650 battery 2-button EDC flashlight looks like a retro model for the taste of experienced users.
If we compare Wurrkkos FC12 with it`s full analog Fenix PD35 v3, for me, the latter looses in everything. In everything except stabilization and thermoregulation - features that you wouldnt expect Fenix to be better at.
But Fenix should be better more reliable, i cannot deny it. I’m always ready to kick Fenix (I wish this kick would give them acceleration and the right direction), but their flashlights are actually reliable and I am confident in advance that the PD35 v3 will also be indestructible.
Only long time use will show how reliable Wurkkos FC12 is. Although with a colossal difference in price, you can close your eyes on this.
In general, Wurkkos FC12 turned out to be another inexpensive and remarkable in terms of light and UI model for an ordinary ordinary user. I am sure that the disadvantages that are important for the experienced user here, an ordinary user , most likely, will not notice.
