Hi All
Long time no contribute anything…
We live in an old house, with only one power point in the bedroom - on the opposite side of the room.
So my bedside reading light has been this ghetto creation, which has served well, but there is room for improvement… ![]()
I love old vintage lamps, so I scored a couple of these French railway lanterns (1940’s or 50’s?) from a really helpful guy in France (yay eBay!)
I removed most of the old paint with a wire brush, and then with a soda blasting kit (they are really cheap, and good for the detail bits that the brush can’t get)
Then out to my modern, well-appointed paint booth for multiple coats of hammered-finish grey…
Once dry, it was baked in the oven for a half hour for a really hard finish.
I designed a heatsink/reflector, and got my friend the expert machinist to build it for me.
My little lathe was too small to do the machining, but it did fit in the chuck so I could polish it with some jeweller’s rouge (polish).
The LED was bonded into place, and the reflector pressed into the recess in the lantern body. It is a good press fit, so I just used a couple of drops of thermal adhesive to give at bit of extra stick-in-place-ness.
To drive the LED, I designed a little constant current driver pcb. The LED has 3 levels of brightness, chosen by the rotary switch on the top. The driver board also has drivers for a future RGB led to be fitted facing the rear. The original lantern had a red lens facing rearward, and cutouts in the reflector to allow a little light to shine back.
My original design was for a twin-pole rotary switch, to chose Low-Med-Hi-R-G-B, but unfortunately the switches are physically too large, so I have had to drill an extra hole in the top and fit an On/Off switch. This is the only non-original hole I have had to drill.
The PCB and 2 18650 batteries are mounted on a piece of aluminium, which is bent to shape to fit the battery compartment, and doesn’t require any holes to be drilled in the body. Sprayed and baked to keep it looking nice.
And here it is, all fitted together:
If you are wondering why the wiring is so long, its to allow the PCB/Battery plate to be removed and modified in the future, so I don’t have to try to work ‘inside’ the lantern.
And the beamshot - its quite a wide angle, and its a beautiful warm cozy bedtime reading color!
So, in the end it probably would have been cheaper to get an electrician in to add an extra power point in the bedroom, but now I have a happy, one of a kind bedside reading and general purpose lantern that will get daily use - and as you know, building it is half the fun!
, especially if the housing is aluminium (it looks like it?)
