I said I wouldn’t… but I’m ordering resistors for other drivers so why not bump up an already decent light? Right now I’m looking at about 4.5A, which after some more research into SRKs, is a bit low in comparison.
I’m guessing the R4-R5-R6 are the ones to be tweaked. Any ideas? Should I put some specific resistors in my next order, or try a copper bridge on one/two/three of the slots?
That driver hasn't been given much if any attention yet, get better pics - more light, lots more, no flash, and macro mode if your camera has it.
If it turns out those resistors really are sense resistors, you can do a fairly low risk test. Rig it up on the bench with just one cell for power. connect to a test LED mounted on a small heatsink with an ammeter inline. Power up the driver and bridge the resistors with tweezers and see if/how much of a change in output it makes. Most tweezers will be quite a bit more than zero ohms, they're a rather long current path. Depending on what you get with the tweezer test you can add more cells in parallel and go to progressively better conducting jumpers, checking output at each step. Even if the driver has a stroke and goes full direct drive when shorting the resistors, with only 4.2v input you're not likely to fry the LED.
I have modded a identical driver, from a SkyRay Kung.
I soldered cooper wires over the resistors at R4 R5 and R6 positions + the 000 resistor at the Q1 position.
After 1 min, the transistors did not even get warm.
I do not remember exactly the boost in current but it was approx double. Probably it depends on the batteries used.
In my case, the mod was a great success, the flashlight works great and was much, much brighter.
I also modded a almost identical driver, found in the 6x XML2 Skyray from fasttech. That driver used only one transistor and only a resistor found at the R4 position from what I remember.
