I’ve been using an IR thermometer to find cold spots that i can better insulate in spring (the front door is really bad), but i am getting odd values, the device is locked into a 0.95 emissivity assumption, but i am checking laminate floor, plaster walls, vinyl (on windows), concrete, wood, brick, ceramic tile, drywall and glass.
Does anyone know how to correct for these considering the device assumes 0.95 and i cannot adjust it?
I just took mine outside where the ambient air temp is currently –10C. It started at –5 and every time I pulled the trigger it would decrease by another –5 or so, until it ended up at –25. Then I pointed it at the wireless sensor that is transmitting a temp of –10, and it tells me –20. I think this one is going back. It’s a ‘Mastergrip’. I saw one on Banggood that is rated for up to –50C, think I’ll give it a try instead.
I saw one from US dealer that was posted on BLF a while back, brand name and calibrated for $25 plus shipping (which was a few bucks), i would spend the money and get a good one
This is the one I was considering from Banggood. Maybe dig up the link for the one you’re looking at and we could compare and see which one is better.
I was also wondering if it would be worth it to get the energy meter or not. It’s still not really going to tell me how much energy the pump for our boiler or dryer, etc., are using, but it might be of interest, but then again once it’s been used a few times perhaps not.
This is a tough one. Emissivity is hard to deal with especially with limited tools at hand. A simple way to calculate an approximately corrected temperature is to first find the emissivity chart for the model of your IR Thermometer, here's an example of one: http://www.omega.com/temperature/Z/pdf/z088-089.pdf Divide your fixed emissivity by the emissivity of the object you are measuring, then multiply that by the temperature on your IR thermometer readout. Objects with lower emissivity numbers will be harder for the IR thermometer to read and the cheaper it is the less accurate it will be if at all.
When measuring with your IR Thermometer with a fixed emissivity you have to remember that generally reflective surfaces will not measure correctly due to the reduced emissivity of those surfaces and tendency of those surfaces to reflect the ambient temperature as opposed to showing the temperature of the object itself. For those surfaces you'll need to use a contact thermometer as opposed to a non-contact IR thermometer. If your IR Thermometer is showing you odd temperature readings it's a high possibility it's not because it's broken but because of the material you are trying to measure. This is a simplified explanation of emissivity that I've been able to piece together from my readings on it and I would advise people to go do their own research.
EDIT: A trick I've read of people trying is to put black tape on the reflective object you are trying to measure, letting the temperatures equalize between the tape and the object, then trying a reading on the tape.
Thanks for pointing that out, I think you’re bang on especially when it comes to snowpack. I recall when these things first came out and we got excited thinking you could use them to pick the right wax for your skis only to learn it was not going to happen. I guess before I take this thing back I’ll need to test it properly. I suppose I was thinking that because I was getting such wild readings when it was pointed in excatly the same place it had to be faulty, but I was probably just getting wildly variable emissivity. I’m now thinking that perhaps I need to learn how to find objects in the environment that could return more or less accurate readings and go about it properly.
Inside the fridge, its white plastic and i tried on food as well, on the outside it says 20ºC which is just a bit below the 22ºC of an adjacent inside wall which makes sense.
Thanks for the black tape, i had forgotten about that one
Aha! Now yours is acting the same as mine! I have a feeling it might be us and not the tools. You put some black tape on your fridge, and I’m going to go put some on the snow, and we can report back, at least you don’t have to put your boots on to hold up your end of the deal.
Mine is about 5 years old, the –8 was from previous readings not recent, but outside it says err (only goes down to –39.9) but it always does this, the freezer is also Err
It's possible to have varying emissivity on the same surface based on curvature, how clean it is, etc. You also have to be careful of the distance you are measuring the object from, the further back you stand the larger the area you'll measure.
True, i only measure on flat surfaces very close, i think mine is 8:1 on spot/distance
I found the one i mentioned earlier, its not currently on the same sale but if its calibrated and good quality its worth every penny (and adjustable emissivity)
Well, I took a dark blue nylon stuff sac and patted it into the snow, then took readings from about 12’ and 5’. I ended up with –34C, again it got colder with each reading. The outdoor ambient temp right now is –11, so it seems rather odd, don’t know what to make of it.
i forgot to mention, the metal inside the sensor hole really affects the readings, if you leave your finger on it for a minute your readings will rise like crazy, so i’m not sure if your supposed to let it acclimatize to ambient and take temps or if it is calibrated to work with it at ambient and you should not allow it to fall below room temp
Edit:
Don’t touch the sensor itself, oils from your finger may throw off all future readings (not sure if it will but don’t take the chance)
