Welcome to BLF gabbyparker! :slight_smile:
If all you have is a cheap XML light anything will probably be much much better. That said i would also recommend the BLF A6 over the Convoy S2/S3. They are very similar except the A6 is more powerful if you need and has many more modes, including a very low one that’s very useful in many situations. The highest mode will blow you away. Note that you’ll need a high drain 18650 like a Samsung 30Q to get the best out of it.
As said before, think twice before using this kind of light for biking. It will likely annoy other drivers coming your way.
And the traditional BLF warning… Once you get the taste of powerful budget lights, you may well get hooked and spend way more on flashlights, cells and chargers then you ever though you would… :person_facepalming:
