Best for accurate capacity readings?
I have a Nitecore I4 charger that I’m quite happy with… it charges my cells, and shuts off when they are charged.
Now I have many old cells that I’d like to check the capacity on. What charger to choose? The level of details that HKJ goes through is too much for me, I just read the conclusions. My interested is, besides charging my cells, is to have the possibility to check capacity accurately. I did read that the Opus BT-C3100 could give inaccurate readings (not sure of that’s on capacity tests or not). But is it still the best for capacity readings?
A side question: I understand that for a full capacity check the cell must be discharged. Do the chargers fully discharge the cell? The little knowledge I have is that 18650 cells should not be discharged below a certain point. Does a capacity test discharge take this into consideration?
The BT-C3100 has issues with the reported charging capacity, which is of limited interest to begin with, since what
you really want to know is how many mAh can you get out of before you hit the low voltage cutoff. If you really want to measure the charging capacity accurately, just buy a bigger AC adapter for it, 6-10 amps at 12 Volts fixes that problem.
Yes, the discharge test will stop when the cell reaches the target discharge voltage.
In terms of ‘bang for your buck’, the BT-C3100 is hard to beat in a 4 port charger.
InNiCd and NiMh cells, you have to ‘cycle’ them a few times to get to full capacity. This does nothing
but shorten the life of a Li-Ion cell. There is no such thing as conditioning the cell for Li-Ion batteries.
Your best bet is the BT-C3100.
Alternatives are:
1) Chinese capacity measurement devices, I have not tested any, but they are probably better than the BT-C3100 for some test.
2) The CBA from West Mountain Radio. This is a device designed for discharging batteries, but is fairly expensive.
3) A electronic load. These often have build in program for battery measurement and are fairly accurate (I uses them).
4) A real battery tester. They cost a lot of money.
There is some difference in current range, some devices can handle high current, other low current and some in between.
I now have the C3100 charger. To get the most accurate capacity readings, is it better to first charge the cell and then manually select the discharge function instead of using the charge/discharge test function? Is the discharge reading more accurate?
Where can I read about this problem that a bigger AC Adaptor fixes?
^ +1
