have 8 like new 18650h moli cells that i took from a possibly new but obsolete pack.
but the goo strips on these are proving to be tough to clean up.wont roll off under my thumb,goo gone nor carb cleaner will dissolve it.
whats everyones favorite goo remover?
I'v used kerosene - a cloth damp (not dripping) with kero and do it in stages
is it white and soft like dried caulking compound?
a wooden chopstick or kebab skewer worked well for rubbing it off. Need to be careful, we don’t know what kind of plastic is in the insulator between the + pole and the casing.
Gas works very well, even better than goo-gone. Just you’d want to put a bit on a rag and use it outside (because of the smell).
try using a degreaser
Try Goof Off. Goo Gone’s much stronger big brother.
Comes in a small yellow can. Cleans up what others leave behind. Very potent.
I roll mine in cat fur, that usually works. :bigsmile: Or if you have some lighter fluid around that might work too.
I just use Goo Gone.
i just scrape em with a razor blade at a 90’ angle, they peel right off and never nicked the shrink
have you tried the wd40 no mess pen?
I chip it off. Goo Gone gets rid of the printing. :(
Seconded, WD40 works.
The printing on some cells is incredibly easy to make disappear. On Samsung cells, you can take it off just with a little bit of the natural oil on your fingers. So you can probably imagine what WD-40 or kerosene would do.
If it's gooey adhesive residue like from tape, use a dry cloth. If it's cured adhesive, like silicone, scrape it off.
I'll add a technique for removing gooey adhesive Roll up what you remove in a ball and use it to pull more off the battery. I might try tape too.
Most of the adhesives you will come across are oil based, ergo - use any oil as a solvent. Canola oil, peanut oil - anything. The trick is to get as much of the adhesive off as possible, by rolling, scraping, rubbing - whatever; so you are not trying to dissolve hunks of it.
Goo-gone..., sure it works, but is very harsh. Much better is what they use in the medical field - Solvo-Plast. It removes the "sticky" left over from bandages. (And it doesn't smell like the inside of an engine). Should be able to pick it up in any decent Drug Store / Pharmacy.
Isopropyl Alcohol will remove indelible felt pen from most hard surfaces.
i have tried everything but gasoline.
worst stuff i have seen.most can be rolled off with my thumb.not this stuff!
i could smash the cell with the pressure it would take to roll this stuff.and yes i can dent a cell by hand.similar goo on some 0v ones that were recycling can bound.dented them trying.takes less force than i expected.
so dont put batteries in your back pocket and sit on em!
