Best Practices for using a twisty
Well, I can’t seem to find the answer so it must be obvious, but……
When using a twisty, is best practice to twist the head or the tail to turn off/on? I have some Kaidomain buckles in this case.
Either, it is the same, using one handed, it is usually the head that gets turned.
Obviously for lights with both head and tailcap that unscrew (’d’oh)
— Count the number of threads left on each end after definitely turning the light off. Use the one that leaves more threads connected
or
— Use the head end if the tail end has a lanyard loop that you use, lest you one day find nothing on your belt but the tailcap, and the light lost somewhere behind you.
Just twist it the way You feel comfortable.If it lights up,You did it right…
^ cosign
:smiley:
This makes sense to me. I had thought that perhaps some type of wear and tear was less desired to the head or tail. As nobody has mentioned this, I’ll follow the advice above. Thanks everyone
