Best SK68/SK98 or similar for EDC ?
I bought a bunch of SK68’s off ebay for EDC and aside from the cheap plastic lenses fogging up was very happy with them. 2.5 years later I either gave away, broke, or lost all of them.
I want to buy another bunch of zoomers I can use at work, and in general. I like the size of SK68’s but the extra output of an SK98 is very appealing.
I am looking for something with lots of output, mode memory if there are multiple modes, and a glass lens is an absolute must.
Of course it doesn’t have to be an SK68/SK98, anything that takes a single 14500 or 16850 battery will do.
Does anyone have any suggestions ?
The cheapest smaller than sk68 clone
http://www.dd4.com/goods/Meco-CREE-XPEQ5-600-Lumen-7W-Zoomable-LED-Flashlight-1xAA14500_52405.html
Not glass though
why would you EDC the worst cloned POS of them all?
As for the SK68 lights & it clones, the original real Sipik Sk68 is my favorite of the bunch over the clones. ( but they are getting hard to find now as even the fakes are using the Sipik name.
Because they’re cheap as chips. I can’t understand buying the Olight S1 as a jobsite light myself. It’s so small that I’d stand a good chance of losing it, at at $50 retail that’s a hit I don’t want to take. The SK68 clones can be had for $4 to $5 or so - if I lost that I wouldn’t be happy, but not S1 lost level unhappy.
A Convoy S2 or S2+ is a much better choice. If you carry a light might as well be a good one.
Even then it’s 2-3x the cost. If I have people “borrowing” my flashlights I’d hand them the dirt-cheapest thing I could. My Convoys are for me. :smiley:
Besides, most times you just need light - don’t matter how “good” it is.
edit - just had a thought. If I were really concerned with losing the light, I’d get a few of the $1 or $2 specials from the dollar store. Although the SK68s are a fraction more durable. But not much more.
Hugsby XP-11. They are cheap and good quality for the price. Can be bough for slightly more than $5 on ALiExpress
These “600lm” ones are the worst. Anything with the same factor as original sk68 are better, in my opinion.
I would trust these guys. Not the cheapest but...
http://www.mtnelectronics.com/index.php?route=product/product&path=80&product_id=319
All of those have been good. I think that the SK 68 is too large for edc.
I prefer these for edc, and have no complaints with them. Even these are too large for me. I much prefer
I much prefer the HAIII Buckle. It is not too large, and for EDC the single mode works well.
http://www.kaidomain.com/Search/SearchResult.HAIII%20Buckle
Jerry
+1
KD HAIII Buckle V6 for the win!
How worst? Kindly explain?
> How worst?
Look up "#3 zoom" in the Search box for more about them.
They have less metal than the SK68, so they heat up faster.
They are often even more crudely made, the hollow pills may have notches that look hacked out with a chisel.
They vary a lot -- you won't likely get the same thing from the same supplier reliably.
Some of them have threads that will interchange or lego with the "3 watt police" tubes (that's a particularly execrable blue-white cheap light). Some of them won't.
The emitters in them barely contact the little ledge inside the hollow pill. Levels: Medium, High, Disco, "next mode" memory
I like them best these days for cheap lights; the advantage over the otherwise much nicer "buckle light" is
-- they cost half as much
-- they can be modified
-- they are tolerable with alkalines and, for gifts, decent with NiMH or Energizer lithium primary cell.
-- with a metal saw or file, you can remove the smooth part of the slider and get a markedly wider flood, without having the lens interfere with the emitter, and no loss of focus
hank had given may valid reasons. My main complaint is that they have very weak output. It claims to be 600 lm but actually are only about 30 lm or less. From my uncalibrated IS, the SK68 clones that I bought from Amazon are about 50-60 lm with one Eneloop AA rechargeable. The two I bought from Banggood are about 20 and 30 lm respectively. The absolute numbers may not be accurate but the relative numbers should be correct. Their colors are also quite purplish. Not my favorite color. In particular, I don’t like people make known lies. I think this would also reflect in the product quantity.
Hi, hank.
Thank you for the good summary. However, I have a couple of comments and questions.
For price, I think one can get SK68 clones for around $3. These are lower but not half.
I have more difficult time to disassemble them compare to SK-68 clones. Can you give me some hint how to open them up?
The last two lots of Meco zooming lights I've bought do not have Cree leds in them. One batch had an imitation XML and the other an Led I could not identify. Both lots from different suppliers. I have another batch on order from DD4 but dont expect these to have Cree Leds in them as well.
For 30 lumens, i dont think heatsinking will make a difference. For quality problems, that also applies to sk68. I think the only difference between this and sk68 is that you sacrifice modding potential for smaller size.
If if you use it as it is, or give it as loaner will never return lights, this i think is a good choice
I think these are fair statements. I may have better luck with SK68s than these “600lm” ones but my samples of the latter are relatively limited.
UltraFire says it’s a Cree but has a plastic lens. It’s a decent light for un-pampered use and to give away because non-flashaholics will have AA cells or can get them, with a much better power-factor than AAA.
Losing, gifting, or destroying a $5 light hurts a lot less than if it was a $30 light.
Phil
