Better batteries give Higher outputs - its true. Time to swap to 21700's
For many on here this will clearly come as no shock at all. And for many years on BLF we have loved lights with a direct drive ability and the use of high current batteries. But with the advent of many multi emitter lights and/or single LEDs capable of utilising much higher currents. This difference seems to be a widening gap.
I’m fairly new to the 21700 party, but I think I could be a convert. And thought I’d compare a couple of lights with some different batteries and the difference between the highest and lowest performing batteries was quite stark.
The lights in question:
Familiar lights here on BLF.
The batteries in question:
Samsung 25R | Samsung 30Q | Samsung 30T | Samsung 40T | Keeppower IMR | HLY 26650
All batteries are new and fully charged for the test. Except for the 25R and Keeppower. Both of these are older batteries. I have a number of 25R’s and they all seem to perform about the same. The Keeppower claims to be high performance and I have no reason to believe it wasn’t genuine. It has only been lightly used but is a couple of years old, so should be in good condition still.
Unlike some on here, I don’t have an accurate way of converting to Lumens. So I’m just using relative difference in Lux from a bounce reading. I’m using Ceiling Bounce on an Android phone. So this is only a guide of trends, rather than absolute figures. But should be enough to give an idea.
I have also only used PEAK Lux. I have not measured to ANSI FL1 or after a set time. Although in most cases the PEAK on turbo was usually 1-2 sec from turn on. While the PEAK on High sometimes took 10-15 seconds on time.
As you can see the 21700’s easily recorded the highest outputs. Considering the price of 26650’s vs 21700’s I see no reason to continue to buy 26650’s and would almost question lights being designed for 1x26650 that they should consider slimming the flashlight down to 21700 size. 18650s probably still have a place in EDC lights, as they are physically smaller by a fairly noticeable amount.
The two oldest cells also measure the lowest outputs… is this coincidental?
Maybe. But I think it is more a case of there are better batteries these days. I like 25R’s. I have loads of them, but in almost every light I’ve tried the 30Q’s match or exceed them. Despite the published claims.
That said, I’m not willing to buy a new 25R or Keeppower just to retest :wink:
I have an Efest, Kingkong and some other 26650’s that seem to perform similar to the Keeppower in other lights I’ve measured amp draws on. I suspect more likely the Keeppower never met the specs printed on the label.
Nice test. How did you fit the 21700 in a 26650 light? Did you use a space or did you just put it in and use the tail cap to hold it in place? Some 26650 light might not have long enough body tubes to fit a 21700 also.
Thanks for posting this, useful info. :+1:
Are you going to test Shockli black ? as it seems to be the general preferred performer for a 26650.
cell design is a compromise
usually higher max output = less total energy contained
there is different chemistry, plus cell geometry for maximizing one or the other
the point is, you have to choose, usually
high output cells also may not retain their peak output very long, either, they can get worn out quicky and capacity and peak output can fall off
wle
Ok, so I can certainly agree with the above. Fresh 30T in the FT03 tonight instead of a 30Q also new.
Was there a difference - OMG yes. Immediately you could see it, and after a lil while on turbo I was wondering just how hot it would get! Those 30T’s are the nuts.
No light boxes needed, can see it with your eyes easily - the thing barely gets warm normally with the other 30Q’s I have, now it gets proper warm. The beam feels noticeably hot too, which I never noticed before.
So, should you buy a 30T for the FT03? oh yes. :+1: Mine has the XHP50 btw.
Without considering cell size and weight - I’ll take better effective capacity over a barely perceptible output (and consequently higher heat generation) any day. Without comparing to tests of these cells are whatever current the lights are drawing the test lacks a significant amount of context to make a judgment on the practical benefits of one over any other.
26650 chemistry and construction will see the benefits of what has been developed for 2X700s, just as 16340, 18350, 14500, etc. have seen considerably improved versions released in just the last couple years.
Sure, current 21700 cells can achieve higher turbo current than 26650s. But there are no 21700s above 5000mAh, and my Shockli blacks are good enough for high current without sacrificing the capacity. But I guess that’s why I’ve always been fine with 30Q/MJ1/VTC6, since I’m never chasing the last few lumens on my hot rods. It’s also why I don’t own any 30Ts. Will current chemistry advances ever reach 26650s? Maybe.
As far as 21700 vs 18650, I don’t see it happening. The 18650 form factor is the largest I’m willing to pocket carry regularly - and even then, it’s generally the more compact examples. And when we’re talking about EDC lights, the last few lumens out of turbo matter even less to me.
This all said, I’m excited for multi-cell 21700 lights to really push the amps!
Depends on the application. EDC light: I agree higher capacity is preferred over HEAT. And… 21700 lights are harder to carry too. That said I LOVE my new S21b with the new Osram using the P42a Molicel 21700.
But for my hunting rifle lights I build, the smaller the body’s form factor (tube), the better. AND… I am using the highest drain 18650s I got in Conyoy’s C8+ right now (to max out throw using the Osram emitter there too). The run times on a coyote hunt are a few seconds after locating the ’yote using night vision. Light up the field, make the shot… done. Light on the gun isn’t used for searching, or anything but making the kill shot. The C8+ also has excellent heat sinking so perfect beta host for this latest gun light.
So if you need short, super bright/throw like me, and in the smaller host possible… I am glad to have a nice selection of 18650 batteries to choose from. :smiley:
While I’ve been aware of output differences between lights using 26650 and 21700 batteries for quite a while, I’ve only started to check the actual differences with a Lux meter recently and found it pretty significant with the batteries I have (mostly Molicel P42A and Liitokala black 5000mah). I still find 26650 batteries useful because of the greater capacity. I use high output 21700 batteries in my “big lumen” lights that take them but If I’m going for a long hike at night for example (which I really don’t do often unfortunately) or ceiling bouncing for light during a black out (frequent here, lately daily), I will switch 21700’s for 26650’s. I would be at relatively lower outputs to extend the battery charge and I don’t care about the “wow factor”. Also for me 26650’s are cheaper.
I’m sure there will be advances in 26650 tech but not at the same rate as 21700 and 18650 batteries because 26650’s are not as widely used in industry.
I’m glad I finally got the lux meter, it’s been a lot of fun and I can test things that didn’t even occur to me before getting it. Raises a lot of questions for me though.
Thanks for running the test.
I always liked the 30Q because of their decent capacity, good current, price, and availability (U.S.A.)
Now the 40T seems to have fulfilled those same qualities for me in the 21700 format.
No... it better not be time to make the switch
How many 21700's do you have vs.18650's ?
I have three 21700's
and about
seven hundred thousand 18650's
I don’t care about heat really and if it was nearing a problem I’d mod it, for what I am using it for I specifically want max output in very short bursts. As for capacity - As it goes the 30T and 30Q I think are pretty much the same capacity - so it makes zero difference. I do not own any appropriate 26650’s.
I can tell you now - it is not just chasing a ‘few’ lumens either……… few hundred may be more accurate. These batteries were both brand new out of the box - the difference was considerable to the eye.
I use this ft03 to quickly flood a big set of fields on turbo, looking for eyes (deer or fox), maybe 1 mins max at a time - then I’ll switch to the GT to hone in, the FT03 is not a spot so is useless for this. The rest of the time it’s used on low to see the way (ft03).
Granted, if I was out for a weekend camping and needed it to last the whole trip I MAY opt for capacity - or I could just take another cell.
I am not suggesting switching lol, merely pointing out what chickendrumstick said is correct, and more :slight_smile:
The Astrolux MF01 Mini and EA01 come with a very nice nylon adaptor. It has an o-ring recessed, so it doesn’t fall out of the light either. And also as an extra 18650 insert. I’d like to know a supply of these as I can’t see them on Banggood apart from with the lights mentioned above.
I’ve tried a few of my 26650 lights with them and assuming they body can physically take a 21700 they have all worked.
I don’t have any of those. TBH I think in the future I will not be buying anymore 26650s and will just use 21700 (assuming I have enough adaptors, although would be easy to make one). The 21700 batteries are quite a bit cheaper to buy and I can easily buy a non branded Samsung in these, so I know what I’m getting. The 26650’s always seem to be more of a gamble.
I tend to only run IMR batteries in all of my lights, as they suit my usage most and type of lights I own.
Yes, for me I think the 40T is the sweet spot also. The 30T might give a bit of an edge in pure output. But not enough considering it is 25% less capacity. I also agree about the 30Q.
Maybe in the flashlight community it isn’t as widely used but in the powered skateboard/scooter community a fair number of the major brands use 26650’s in their battery packs.
