BIFL EDC waterproof flashlight that's thin like a Peak Eiger but repairable like a Fraz QT-L Nugget
Hey y’all, I’m planning on backing a kickstarter linux device to replace my data-invading phone. It doesn’t have a built-in flash though, so I’m looking to get a EDC that’ll last forever, which means to me: repairability, waterproofness, no proprietary parts/programming, and general ruggedness.
I like how thin the Peak Eiger is, like I could hook it to the device and they’d go right in my pocket together. I read “epoxy sealed head” though, and it sounds like it’s not really repairable like how a Fraz flash you can just pop in a new diode. While I’m willing to sacrifice the thinness, do you guys know of anything that is just as repairable and thinner than the Fraz’s 18650 before I pull the trigger?
I also like the QTC simplicity but would not object to a driver if it’s open source like Anduril.
I’m willing to diy, but unfortunately too lazy to machine parts or really do much that isn’t just lego-style plugging together.
Thanks :slight_smile:
There’s really no such thing as coincidences, are there? :wink:
You might want to contact Frazlabs directly and ask if they could design/craft a more pocketable version of their nuggets. It might not jive with their design philosophy, but perhaps you could float the idea of a 14500 or 16650 style light with a smaller overall engine/footprint.
The biggest issue when you go too small is availability of LED pads/stars. You might end up having to file down a star to fit your device, like the older Novatacs used to require.
Ah, darn, so it just a physical size limitation.
Well, at least I’ll have some more battery life with an 18650 lol. Thanks for the answer!
For reference, this is what I currently edc. I believe the switch can be swapped out along with the driver/engine, and it would be relatively “simple” (but tedious) to fashion a Fraz-esque engine to fit in here. It’s designed for a a 16650/2xcr123, but with a brass signal bar, it currently houses an 18650.
Never hurts to ask FrazLabs directly, I have a feeling that the company is comprised of exceedingly clever individuals.
We’re very glad to have you here, 1flashperson!
The problem with QTC material is that it’s not very durable, or at least that’s what was posted on many BLF years ago.
I believe the issue has typically been overcompression with no limiting guardrail…like a memory foam mattress that has exceeded its weight rating.
Welcome to BLF!
I’d argue a Convoy S2+ is equally repairable, and is 24.1mm diameter (Vs 30.7mm). Parts are near enough generic by now. If a moron like me can solder a new LED or driver, I’d say anyone slightly practical can do it!
By all means, get the Fraz if you’ve an itch for one, but I’d go with a Skilhunt E3A or something for daily carry - okay it’s not rugged and highly repairable, but it’s small, and arguably the best light is the one you have on you…
That looks way more pocketable. Might as well stick it out with 18650 because I already carry a few other things that use 'em. I may have discounted the Convoy during my research because the driver seems to be closed source, but it’s so cheap I could always get another if parts are so generic, lol.
Is the consensus that the SST-20 4000k is well-balanced?
My wallet would like to thank you for your swaying opinion rofl
Yes, the Convoy driver is technically closed, however:
  1. There’s some work going on to develop some re-flashing hardware, firmware is still not developed from what I understand, so you’d be on your own.
  2. (Almost) any 17mm circular LED driver will be compatible- these are widely available, but specifications (topology, UI, thermal/voltage protection, power output) vary, so your 2025/2026 17mm 5A buck driver from Convoy might not be available in the exact form some time in the future, which is only a problem if you are deeply attached to specific user interface or mode spacing, etc and are unable to find a similar replacement.
Hey I’d pulled the trigger and I’m very happy with how well it fits in my pocket.
That said, it’s a little sad with the pocket clip you can’t fit the magnet or the wristband (see image attached of the little blocking bolt buggers).
Do you know of solution that would let me have all three?
If you have access to a very precise lathe, perhaps get a tap to put threads into the existing holes that correspond with a shorter screw. At the same, tap a couple holes on the opposite side to attach a wrist strap?
Lol! I appreciate your trust in my machining abilities but my lathe experience begins and ends with wooden bowls >.< I think maybe another whole tailcap might be necessary?
I have got no idea, lol…I don’t have an S2. This might be my sign to get some variant, though…
If you’re not afraid to potentially mess something up, perhaps shorten the screws a bit, put some heavy duty epoxy into the holes to “glue” the screws and clip to the light, then tie off a lanyard to the crossbar of the clip?
