Big gun! Trustfire flashlight AK-91 LED Cree XM-L T6 15*Emitters Max 4300 Lumens 4*26650 Batteries
Brand: TrustFire
Model Number: AK-91
Material: Aluminum Alloy
Color: Black
Size(mm): 415(L) X 89.5(Head dia)
Weight(g): 1006(without battery)
LED lamp: 15 * CREE XM-L T6
Lumen: max is 4300 Lumens
Mode: 5 (High 4300lumens-mid 2100lumens -weak 400lumens-Strobe 2200lumens –SOS 4300lumens)
Switch: Tailcap Click On/Off
Lens: Impact-resistant optical lens
Reflector: Aluminum Reflector
Run time: High 60min(Use4 super capacity of 26650 batteries) ,
Finish: Type II hard anodize
Waterproof: IPX-7, unable to support dive use
Working voltage: 16V ,Max out current 16.8A
Battery Type: 4 x26650 (protection battery)
Application: Camping
Compare to the AK-90, the emitters are upgraded to 15( AK90 is 12)
pssst… you forgot to include the price :stuck_out_tongue:
If you have to ask, you can't afford it.
I just got the basic information of AK-91, and fastly share the information with BLF membets, not get the exact price yet, if I get, I will update it immediately
To late. I just ordered one of these instead:
http://www.gearbest.com/led-flashlights/pp_19385.html :bigsmile:
Interesting light and not bad of a price.
I’m glad that the light isn’t advertised as ten times the actual output, good job!
Thanks for the BLF discount.
Yeah, I gave the actual output, the mark is 18000 lumens :stuck_out_tongue:
hmm…very tough decision… TR-J18 is around $45 and with simple resistor mod it will push around 4000+ lumens
extra $20 for beast driver and you can get well over 5500 lumens.
I just bought 15 LEDs supernight with identical head with that light for less than $95 shipped from USA
look like you have to find a new supplier for your lights.
I’m going to wait until they come out with 15 XM-L2 U2 LEDs :smiley:
Why so many emitters? If you drove each one at a mere 1 amp you would be right on the Linear part of the Amp to Lumen scale, and you’d wind up with 7500 lumens approx.
Running at 2.8 Amps, a mere 5 emitters will hit over 5k lumens.
This just seems like a waste of emitters, when they are all driven so low. You aren’t really getting much more efficiency out of them once you go under an Amp.
more flood :bigsmile:
Maybe I can’t change the supplier, becaue I contact with Trustfire factory direclty :slight_smile: , anyhow, thanks for your suggestion!
