Got an HS05 with the $3 off code, so thanks.
Jackie
(Jackie)
323
12% presale of SP33S CODE--PRESP33S ,use XHP70.2 6000-6500K LED 5000LM output, compatible with 26650/21700 battery, Type C charging and reverse Charging Max 5V 3A
50 pieces of first batch in all
Link of SP33S: https://www.aliexpress.com/item/1005003438724316.html?spm=5261.ProductManageOnline.0.0.31114edfStG4nZ
Jackie
(Jackie)
324
Sofirn New Model Presale, shipping in 5-7 Days, first small batch of HS10 16340 Angle Light, work as a headlamp, 1100lm by LH351D 90CRI
LEDs. Enjoy coupons ordering on 11.11 deal day! Thank you.
max
(max)
325
Thanks Jackie, code worked, just ordered two more SC31PROs.
Jackie, you didn’t include a link to the HS10. I found it here .
DC74
(DC74)
327
Hi Jackie, is there a code for the new hs10 headlamp?
Jackie
(Jackie)
329
yes, here update :Q21DTP3E1BLK
Overload
(Overload)
330
Thanx for the code, bought one! :+1:
xevious
(Gary)
331
Would be nice if the HS10 had an 18350 body option. Just a nominal size difference yet big punch up in mAh gain.
eman816
(eman816)
332
I’m curious about the c8l is it 21700 like the g and f?
Jackie
(Jackie)
333
Black Friday Deal start from 25th to 29th, more codes will update soon
Jackie
(Jackie)
335
$2 unlimited code 30 pieces --1QMYAPO4H7LV
$3 unlimitd code 30 pieces---9ULIBJ6NNU3N
valid time from 25th--29th, during black friday deal
Kos70
(Kos70)
336
Thanks. I took advantage of ...
Jackie
(Jackie)
337
On Deal Now, thanks for all support
Jackie
(Jackie)
338
$3 unlimitd code update---9ULIBJ6NNU3N
m47mu74nt
(m47mu74nt)
339
hi ! I’d like to buy HS40, but only if the head can work on SP40 bodies (19650 & 18350) ?
thank you
d_t_a
(d_t_a)
340
HS40 and SP40 body tubes can be used interchangeably, as shown here.
(the body tube knurling pattern for HS40 has been changed to a horizontal instead of diamond pattern on the SP40)
HS40 does not come with 18350 tube though (but can use the SP40’s 18350 tube)
HS40 uses USB-C (tested charges at up to 5v/2A - so one shouldn’t probably charge an 18350 battery using this),
(USB C-to-C cable charging is supported)
while SP40 uses micro-USB port.
