Hi friends.
I need advice from people who knows about hobby BLDC motors like the ones used in drones or rc planes.
I have a 1000kv bldc motor that can be powered up to with 4s max…
There is a lot of contradictory info on the web…
Some say thay can be used as generator.
Some say that can, but you will get about 80% of the volts and amps it takes when using as motor…
Any idea?
At 16.8 volts (4s) it should get 16800 rpm and it gets less than 20amps full load.
So… If I spin it at 16800 should I get something usable??
Anyone tried??
I know that the best bldc foe use as generator are the one with lowest kv… But they are expensive…
Thanks in advance!
