Took me some time to understand the circuit....
If I understand correctly it is basically two different circuits: the power supply circuit and the driving circuit (and the OTC):
Br - bleeding resistor is only used for tail light and can be removed.
R1,R2 - are for voltage measuring for battery status.
R3,R4 - are for driving the FET (only for turbo) eliminating current spikes back to the MCU(?)
R5,C1 - Low pass filter preventing current spikes to the MCU.
C2 - I don't know what it is for.
D1 - reverse polarity protection(?) decrease input voltage at about 0.2v.
D2 - Zener mod to provide 4v to MCU while input voltage is 2s or more? (can be removed if only using 1s)
1*7135 - connected to PWM for moon milk and to reduce power consumption for higher modes.
8*7135 - connected to PWM for modes up to 2.8A.
FET - connected to on/off pin for Turbo only.
THX for the Tip.
Couldn't find it using the forum search do you have link?
