This is another great driver option.
If only its high/turbo modes were regulated at 8A I would certainly consider it.
Great thing about that firmware, you can add and remove modes. It’s highly customizable
That’s right, I almost forgot about that. You can probably remove the modes that would offend? I found another driver similar to it that has a 9A mode that can be programmed down to 8A but its a linear driver and thus dangerous with battery over voltage. I think that equates to heat directly from the driver itself. That 17mm buck driver at Convoy is far more efficient though and only $4.99. Lol
Sorta.
You get regulation up to 3 amps.
Then you have 2 fet modes.
You can combine that with a battery tailored to achieve pretty close to your desired output on max.
Like if you used a 10amp battery, and disable max turbo, I would assume you could get pretty close to 7-8 amps if you want.
But that’ll never be as efficient as a fully regulated driver.
I’ve got an old Q8 that I modded to have 4 SFT40 emitters, and they work well with the FET driver and 4x molicel p26a high drain batteries (bypassed springs). I think the sft40 will handle direct drive just fine. The FET used on the A6 driver is not the lowest resistance as well so that limits current somewhat. Using a battery that isn’t one of the newest tabless super low internal resistance will also help, something like a Samsung 30q will be suitable
OK, so the parts are almost here and I wanted to ask a question about the build.
Thanks for any clarification you can give me.
The head won’t really screw down further, that happens with the threaded s2+ pill but the A6 has an integral pill so that height is fixed. I’d try putting an extra thick o ring under the glass
Absolutely do keep the front glass lens. It protects the TIR and serves as a spacer.
There won’t be 0.2mm of space because the head O-ring is not rigid–it is currently under pressure and will expand to fill the space if pressure is loosened. It’s also quite possible that the head threads have enough give that you can further tighten it by 0.2mm, or that Convoy’s MCPCB (if you’re using that) is thicker than the stock one. In any case, I would not worry about it.
Well today I finally found time to put this exact combo together. And what I discovered is confusing.
The original lens does NOT fit in front of this TIR lens. The TIR lens has an obvious grove in the front for the rubber oring that fit perfect. But you can not screw down the lens host fully with the original lens still in place. You just hear a crunching sound and you can still see threads. I had to omit the original lens and only use the rubber oring and tir lens and then it fit perfectly. You can still feel the tir lens touching the mcpcb. I didn’t expect that but it seemed to be fine.
When I turned it on for the first time I was amazed at what I was seeing… but that was short lived. The led started to turn blue and then I heard popping sounds (melting plastic) and saw smoke as the led died. The TIR lens nearly fully melted and the led/mcpcb turned black. So I am confused. I used high quality Noctua NT-H2 thermal compound too. So not sure what happened. Is it possible convoy soldered the LED on wrong? I am 99.9% sure the led was seated on the shelf properly too. But it seems to me that the mcpcb wasn’t transferring heat to the host body, but I felt the TIR seating up against the mcpcb, so it was clearly pushing the mcpcb into the host shelf. What gives? What am I missing?
Anyway, I looked up the specs on the sft-25R and its only a 7.5 amp led. Sure it says it can go up to 8.2 amps but I bet that is only if you get a nicely binned led.
So I don’t know what to think. But I think I am going to go a different route. 17mm 3V/10A buck + SFT-42R 5000K and the 5050 5° TIR lens just to have that safety margin built in. If it blows again then something is wrong with the design of the head and how everything fits together. Maybe I should get a second S2+ host just in case these parts don’t properly fit my BLF???
Any Ideas or tips please? Thank you!
Rod
Based on @koef3’s test data on the SFT-25R, which can be found here, pushing the SFT-25R to 7,5A, appears to be already taking it very close to it’s upper limit.
As you stated, a really nicely binned LED might be able to handle it for a long(er) time, but for a regular /average binned LED, it might be close to the absolute limit.
The SFT25R has gone through a couple upgrades since then, and the 8A buck driver gave me no issues (and no sign of turning blue and maxing out). Even with the earlier batch, it should not have failed because the Vf is so high that it’s impossible to get above 6-7A in a realistic setup.
This is very strange. I’ve experienced this once before (519A with 5A driver and same optic), which I suspect is due to the optic being screwed down too tightly and possibly shearing the emitter sideways. I remember hearing a crunch sound then. I would suggest not tightening the bezel all the way down, a bit of a gap is fine.
One needs to be extra careful when the glass is removed, because the O-ring grips the optic and doesn’t let it slide against the bezel. This means the optic rotates against the LED during tightening, and is capable of exerting extreme torque. For this reason, the 20mm 5050 TIRs will not work at all because its centering legs prevent it from rotating around the LED.
You could order another SFT25R along with SFT42R if you want to try that. In the worst case, you can use the default reflector and either emitter will still far out-throw the stock XPL-HD.
Yeah I am confused too. I have some theories but I’m not sure about them.
For one, maybe the BLF host just doesn’t have enough thermal headroom. I mean the shelf is just a thin aluminum shelf. It’s nothing like those brass pills used today. I don’t know how thick those pills are but it seems to me that that’s much better for thermals. If thats the case putting in the SFT-42R will only make it worse.
And, this… Maybe, just maybe I am wrong about that lens issue? Maybe when I removed it I was removing the pressure needed to keep the mcpcb firmly sitting on the shelf. I just don’t know. Shouldn’t there be some kind of LED centering gasket to use on these TIR lenses?
I think it is user error, but I don’t know what error I made. Lol
EDIT: I just saw a post by Simon at Convoy and he says this “When installing this total internal reflection lens, please remove the original plastic gasket and reflector, and retain the original glass lens and silicone O-ring” So when I removed that lens I also removed all clamping force off of the MCPCB and it lifted off the shelf. That is now my theory.
I’m fairly certain that the issue is not poor heatsinking. A thin aluminum shelf still outperforms a brass pill, and furthermore, thermal failure is generally not instantaneous/catastrophic in nature–there are plenty of high-power lights on the market that barely used any thermal paste but still seem to work fine.
If the MCPCB got completely disconnected from the shelf, i.e., is floating in air supported by only the wires, then instantaneous failure can happen. Though this scenario is somewhat improbable because thermal paste sticks the MCPCB to the shelf. In an ideal world all TIRs should have a good centering mechanism that prevents these sorts of issues, but it looks like Convoy’s 3535 TIRs don’t really have anything like it–the emitter just sits inside the round cavity.
Hmmm, maybe this sounds feasible. I wish I could verify it but don’t have an A6. I guess next time one can try to keep the glass and disregard the gap it creates. Assuming that the A6’s reflector is identical to the S2+'s, then reflector+gasket should have the same height as a bare TIR, and therefore should not result in any dimensional issues if everything is assembled correctly.
Actually, after another thought I have another hypothesis: could it be that the TIR is getting stuck on the rim surrounding the shelf (the part with outward-pointing threads that mate with the bezel’s inner threads), and thus not pressing down on the MCPCB at all? If this is the case, the TIR may need sanding to reduce its diameter.
