BLF Edition Thrunite Saber 1A & 14500 Embarrassing Problem
This is kind of embarrassing but I’m out of ideas and need help. I got my light in after waiting 5 weeks, and I was so excited that I immediately grabbed a 14500 and shoved it into the tube. One would think this is easy enough, but I made at least a couple of mistakes in the process:
  • I put it in backward (alright already I didn’t have my glasses!).
  • It was a really tight fit, and I should have known better than to persist.
So bottom line is now I have a tube with a 14500 (gray Trustfire, I think) stuck in it, and I can’t see anyway to remove it. I tried centrifugal force, but it doesn’t budge, and I tried prying a small screwdriver under the tape of the endcap and lifting up, but the tape gives way a long time before the battery is ready to. This thing is in there tight.
I’m limited in tools, and a little anxious about trying anything too radical given that it’s a li-ion that I’m dealing with.
Is there a way to get the end-cap off the tube? I can post a picture, but if you can picture the flat (negative) end of a 14500 flush with the opening of the tube, that’s pretty much it.
Any other ideas greatly appreciated.
Pull on the wrapping tape with a pair of hemostats or maybe try a little stack of small neo magnets? Last battery I got stuck worried me until realizing that the other end had threads too :confused:
You need more “centrifugal force.” Securely tape the light to a board, say a 1 x 3 about two feet long, then swing the board into a solid edge to get the battery to fly out.
Sketchy Solution: Run a self taping screw into the end of the battery and pull it out with pliers.
Dangerous Solution: Overcharge the battery until it vents sending the battery flying.
I’ve gotten stuck batteries out by knocking the very edge of the light against a thin sheet of metal. Er, that might not make immediate sense. Basically, I lean a thin sheet of metal up against the side of a vertical flat surface and then slide the light down against the flat surface until it hits the metal. Inertia helps pop the battery out better than the centripetal effect, usually. The sheet of metal must be thin enough to contact the light’s body without touching the battery though.
Strong magnets are also a good idea, if you have, like, a hard drive magnet or anything along those lines.
I don’t have a Saber, but can’t you open it at both ends? If the front has the pill, can’t you take that out using a pair of tweezers or spanner wrench, and then you have access to the front/ + side of the battery. The negative end should be accessible by removing the tailcap. Then you can try shoving it from the front?
Hold the light in your hand with the bottom a couple of centimeters from the bottom of your hand. Hit your fist on the table a few times the battery should carry through with the momentum. If you need more momentum then tape it to a hammer and tap the hammer on the concrete lightly until the battery carries through.
hmm, maybe try to hot glue the flat head part of a nail to the battery and pull it out, or if you can solder some copper wire to it without heating the battery too much, might work?
A+
Get a bowl and fill with boiling water, use it to heat as much of the sabre as you can get in the water without burning you fingers.
Next have a tea towel or rag available to quickly wrap round it when you take it out the water, hold the body and try and knock it out by claping hands together or knocking the holding hand against a stop.
Basic idea expand the tube just a bit by heating
PS I think some folk have fried the driver with 14500’s
Drill a hole in the far end, insert a rod to push out the battery or blow it out using compressed air. Tap the hole and fill the hole with the appropriate screw, seal the threads with Locktite.
Just shot coffee out my nose… Thanks guys…
Solder a wire to the exposed end and pull the battery out.
I like the tape-it-to-a-hammer idea. Not sure if the OP got the battery out yet, but next time I have this issue I’ll have to try the hammer-transferred-inertia thing.
Bump
So, what was the final result?
Me thinks, JohnnyMac is spot-on — Solder Up, Yank it OUT!
+1
+1 that’s the way for sure
I got swamped at work and had to give up on this a while, but I wanted to post an update. I didn’t have an air compressor or even hemostats for that matter, and I thought anything involving heat would just make the tape gooey (at best). However, I did have a hammer and duct tape.
So per texas shooters instructions that’s what I tried. I was skeptical, but it took maybe 30 seconds. I’m sticking to AA for flashlight from now on though.
Who knows how many of the world’s problems could be solve with a hammer and duct tape?
Thanks for all (most) of the ideas. I knew I came to the right place for help.
A degree in chemisty, strong interest in all engineering has nothing over kids. Have kids and you’ll discover more ways to fix things than you ever thought possible. You’ll learn if its small enough to eat its small enough to pass. Positive pressure can get most things out of a nose. Add a few dogs and the learning curve shoots through the roof.
Another vote for the hammer and tape method. I just managed to lodge a protected 10440 cell in a new Tank007 E09. I found this thread, taped the light’s body to the side of a hammer, and within 15 seconds of hammering, it popped right out. Thanks for the suggestion.
I also have the Thrunite Saber, and do not want to go through this same nightmare.
I want to order this Trustfire flame 14500 battery from FastTech (many here gave it good reviews), but I was wondering if it actually fit. It is actually 14.1 mm per specs.
http://www.fasttech.com/products/0/10000523/1084200-trustfire-14500-37v-900mah-protected-rechargeable-
My Eneloops just barely slide in, and they spec at 14.0 mm.
What 14500’s do you guys run in your Saber?
