Bake
(Bake)
9862
Yes DBSAR, I am on the list for two. Numbers 2439 and 2440. I know there were a lot of people on the list well ahead of me so it’s not a big deal waiting in line behind them.
atobe
(atobe)
9863
Have you checked your messages? Everyone should of gotten a message by now, if not message sofirn.
I’ve seen a few photoshopped images showing possible colors, but I’d like to see some actual pictures when the color versions are in production. I’m a big fan of green
but orange would is right up there with my favorite colors.
DBSAR
(DBSAR)
9865
if you have not received any code via PM, please send Sofirn here on BLF a direct message with your list #number.
Sofirn
(Sofirnlight)
9866
Sorry. Sent one code just now.
Bake
(Bake)
9867
Thank you all.
Received the code from Sofirn.
amishbill
(amishbill)
9869
That makes perfect sense. It turns out that I was just being a bit dense I saw the 3H from Off for the fancy blinkies and my brain refused to connect the dots for Tint being 3H from On.
At least I didn’t do anything /really/ embarrassing, like ask a question I’d already documented on a battery wrap & function cheatsheet that’s linked in my sig line… :partying_face:
Thanks
+1
Or, at least some representative samples of what the color will look like.
Depending on the actual colors, green(olive/forest) and orange could be great. Splitting off some threads for an interest list for colors and issues and such, and linking them in the OP might help keep this thread from greatly exceeding semi-gargantuan, and sounds like a good idea if they actually get used instead of everything still being posted in this thread. lol :person_facepalming:
If there’s a tally, add me: I’m planning to wait for colors for some of my remaining numbers, but also would be interested in an un-anodized, etc., version as well.
cu42
(cu42)
9871
I agree. Maybe Barry could post something coated with the actual colors from the factory that does the anodizing. It doesn’t even need to be a flashlight. It could anything made from the same type of aluminum so we could see what the color shade and finish would look like.
I would prefer to see an example and not just a Photoshop of the colors before committing to the list if they start one. The tan is supposed to be a flat finish, but I was thinking the orange and the green were going to be anodized which looks much better than the flat paint look for those colors.
Jensen
(Jensen)
9872
I received a code a while ago because I am somewhere between 1000-2000 in the list but never used the code because I’ve been waiting for an orange lantern. Will my code still work or will there be issues? I really want something brighter than black so I’m willing to wait for it.
saypat
(saypat)
9873
I was told by Sofirn that the code will be good thru December……
DBSAR
(DBSAR)
9874
I am unsure how long the codes last or if they expire, or will work for the later batches. maybe Sofirn or Barry can answer that.
I received more than one code for my three early spots under 500 back when they started sending them out, but since we were asked to only order one, I only attempted to order one LT1. I figured that getting multiple codes was probably an error, and either the code would still be honored once we are able to order more lanterns, or codes will be reissued if they expire. Regardless, I didn’t have any problem waiting a bit longer for something so worth waiting for. After nearly 4 years for this project to reach this point, a couple more months so everyone on the list can get one before I purchase my remaining spots was not a big deal at all. It also helps ease the impact on the bank account.
Since it was promised that everyone on the list would be able to purchase their lanterns at the group buy price, and reading this entire thread over time, I am confident that there is good will at work and with patience, things will be taken care of and made right eventually.
What a great reward for being patient is being embodied in the absolutely wonderful example of a LED lantern that is the LT1!
Thanks very much to everyone involved for all the hard work, you have much to be proud of!
DBSAR
(DBSAR)
9877
Dec,5,2019
BLF member GreenCampfire has been doing some good run-time testing of the LT1 lantern in factory configuration with graphs, the testing can be viewed here: BLF LT1 Runtime test *updated 12/11 with step level 2*
I cannot use the code. It says
Ptomotional code cannot be applied on my purchase
maxacarp
(maxacarp)
9879
Since the codes last through December, does that mean that the codes won’t work for the colors in Batch 3 or we would be issued new codes instead? Thanks!
DBSAR
(DBSAR)
9881
Send Sofirn a direct message with your code issue, they should be able to fix that issue.
