I really hate cheaply designed stuff…but know how to fix it when it goes kaput…
or you got what you deserved for buying cheap Chinese crap
I listen to audio books on my drive to work (really helps me relax to and from work) but used to have to use one of those darn FM transmitter things and plug into my phone in order to listen to the output from my phone to the radio [It takes a little bit to get used to, but now it’s just like I am reading the books, I can remember the characters, the story and everything…]
So I decided to buy an inexpensive (aka “cheap”) radio from China called the BOSS Audio 625UAB Radio (sub $50)…it has bluetooth built into the radio so I can sync my phone to the radio and listen to the audio from the audio book or from mixzing (mp3’s on my phone) and also take calls completely hands free (really nice actually) the audio is adequate but not super pymp hetrodine thumping audio quality that some people demand from their radios, but it’s good enough for my little 4 banger Ford Ranger pickup truck.
First radio I got in noticed right off the bat things were amiss, it claimed 50 watts per channel or 200 watts, but the fuse in the radio is only 10A…hmmm, then I also noticed it was CRAAAAAZY light, the old radio I took out was a JVC hunkajunk but it easily weighed 4x as much as this little radio, the other thing I noticed it no heatsink (I’ll get into that later), put it in no problem and it worked VERY well for about 2 weeks then kaput, knew something was fishy when I smelled the all to familiar hot electronics/magic smoke release…audio went crazy screeching, low volume (more or less fried the amplifier chip…due to no heatsink) (I ran the audio at about 40 on the display, max output is like 54, so I had it turned up pretty loud [I have found the audio boost option on the Smart Audiobook app now so I can run it at 30 rather than 40 as well]
Contacted Amazon and they shipped me a replacement NO QUESTIONS ASKED…got the 2nd one in, decided to do further investigation to figure out why it went kablooey on me
A few photos:
Here are some internals-
Take note there is almost NOTHING inside this darn thing (all digitally controlled and operated which is cool)
The big chip at the back is the power amp, notice the shiny metal bar w/ ribs pressed into it, it’s about 1/8” thick and aluminum…THAT IS IT for the heatsink!
The body is simply pressed steel shell with no real thermal contact or pathway…so I decided to fix that
Right under the green QC tag is the amp chip (notice no real heatsinking and those ribs are actually pressed into the heatsink bar not true heatsink fins at all, suffice it to say, it was REAAAAALY hot to the touch)…
My fix and subsequent not so pretty but functional mod-
I unscrewed the back screws that held the heatsink bar to the pressed sheet metal body and squirted some cheap heatsink in between the mating points and tightened down the screw, so now thermal path is a little better, I also scraped the stickers on both top and bottom that were almost COMPLETELY covering up the air holes that was stamped thru the top and bottom plate [seriously…why would they close them almost completely off…jeez!] I put in my truck and noticed that now the body of the radio gets warm and stays warm but does not get almost too hot to touch after a longer time (meaning the heatsink is dumping it’s heat to the body staying cooler rather than getting crazy hot and then heating everything up)
Ordered two cheap 30x30x30mm heatsinks (I think they were like $3.00 shipped) I epoxied them on top of the heatsink ribs using JB Weld steel, in the hopes that the heat will wick off thru those ribs into the heatsink…it won’t be optimum but it will help alot as it increases the surface area considerably and JB Weld steel is a pretty good thermal adhesive w/ “ok” thermal conductivity, plus the heatsinks are on there pretty darn good…removable if needed, but not just going to fall off.
Not the absolute best fix…but it should be functional and be able to keep from overheating the chip and burning it out…
So what do you think, other than “that’ what you get for buying cheap Chinese crap” ![]()
