Bond wire protection?
Knock on wood that I haven’t had this problem yet, but I can see it potentially happening. I use a lot of my lights of rifles. Some are pretty high power rifles such as my 300 Win Mag and soon a 338 Lapua. I got to thinking which is always a scary ordeal, on my dedomed LED’s I can see the vibrations from the recoil eventually upsetting the bond wires causing LED failure. Has anybody had this happen? Is there anything to put on the bond wires to help insulate them from the recoil?
on my night vision site, we build night vision equipment from scratch, and really i only got INTO this whole flashlight thing, by accident, because making IR illuminators for gun use is half of the battle…
some number of the IR illuminators (LED based) were de-domed… i havent heard of anyone having any problems, but… grant you i cant recall anyone using them on anything bigger than a 270 or 30-06…
so, i will be as interested as YOU when this question gets answered.
LED seal
Which is probably an off-the-shelf silicone spray sealant just relabeled.
+1 on the LED seal. Whats your rig set-up, how are the lights attached? Quad Rail? Scope top mount? Barrel mount? Bi pod mount? Is battery movement restricted or contained? Maybe able to soften recoil with isolators, soft rubber grommet’s? Light placement too? Every little bit helps!
Mounting just varies. Usually on the handguard on ar15 and ar10. It mounts over the scope on bolt action rifles. I never mount on the barrel as it affects barrel harmonics and accuracy. I do use stiff springs on the driver and put high density foam around the springs. Any other suggestions?
im tryimg the liquid tin but does not work on the tiny bond wires unless im doing something wrong ?
i get good results on copper but will not work on the bond wires ?????
?????????? are the bond wires copper ???????????? no?????? they're gold!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! and dang tiny!!!!!!!!!!!!!!!!!
Just givin' ya a hard time Jake.
ill take all donations for junk led's and scrap that gold :)
Haha, 50,000 LED’s to get an ounce
