Thank you, so do you have a single cell boost driver for 6v emitters?
And reading between the lines does you LD-1 (is that the low power or down rev driver?) and it had/has ramping?
I did a search for discreet ramping and did not see the technical phrase used (I assume it is not about ramping but not talking about it )
Does that mean it has it, but you press for each level? I thought the LD-2 only had three/four levels?
I am not trying to set records and I am more focused on getting the most use out of the units, meaning a high/turbo that gets so hot I cant hold it in seconds or a few minutes, is not a good design spec for me.
I like the idea that the new acebeam h10 (A) is a boost driver and (B) to run it on high/turbo you need to hold the button down, seems like a very elegant solution to me. 2000 lumens is too much to “run” the small light at, but as long that the button is held down that it will do it, but upon release it drops back to the earlier state (off, or which setting it was previously set to).
