I’ve talked to chargpt about this but it keeps telling me that this would be hard to make. I’d like some of you guys opinions.
Would it be possible to make headlamp with a ipx8 or ip68 rating,
that has both a flood and a spot similar to the Fenix Hp35r or the Argolamp 2.0,
but Instead of 2 LEDs for the flood, I would like it to have something like the Firefly Novmu mule setup, or maybe a Acebeam E75 but more floody 100 ish degree angle cause it’s high CRI but also constant current,
something that can sustain 800 lumens without dimming,
while also using the spot mode side at a similar output would this create too much heat ? I’m talking about for hours on end
Would it require 1 or more fans ? Could it sustain these outputs with no fan?
My rough estimate would be around 3 amps total for more than 2 hours
That one comes close but the guy keeps giving me the runaround and is not answering my question when I ask him if he uses constant current drivers and the light can actually sustain what his runtime charts say it can.
I am not sure about the OP, but sometimes I want to use both hands for something other than holding a flashlight. I always have a couple of “pocket” lights on me. When doing things like food prep, working on the car, poking around inside my PC, plumbing under the sink… having to hold a flashlight is just not what I want to do.
It frees up my hands so I can do more stuff about hands
or if I fall down when I’m walking
Also, when I’m walking with a flashlight in my hand my hand shakes more than my head, which shakes my beam profile which gets annoying
also even when I have the flashlight on high mode when I hold it next to my waist it seems less bright on the ground because the beam angle is not really a optimal
For example when I have a flashlight on 800 lumens in my hand it seems about as bright as a 400 lumens on my forehead
800 Lumens sustained in a small-ish headlamp is asking a lot. Ive tested the HP30R V2 and HP35R and they don’t sustain that out9ut for very long. Plus, very heavy and limited to basically search and rescue or tasks requiring 500+ Lumens for hours. Thr HP35R can do it. I trstes the Magicshine MOH55 Pro and it’s good too. There’s one from Olight too that has a cooling fan, and I think one from a Finnish or Swedish company. Those are out on 1Lumen (Marco reviewed them). The FireflyLite L70 is a good one too. Not 800 Lumens, but close.
That kind of writing will not make anyone want to help you. I agree that What Sirstinky wrote was very confusing. I couldn’t figure out what he meant either… I can assure you that he is not “stupid”. Especially when it comes to flashlights. He has more experience in this field than most of us around here. He has used and tested hundreds of lights over the years! So, you might want to choose your words more carefully going forward.
