Briefly short circuited 18650 during laptop pull
I managed to short the metal strip on the positive end of a battery to the it’s case about 1/2 below the top of the battery during a laptop pack breakdown. Thin cases wrappers offer no defense against sharp metal strips :_(
It only shorted for an instance but enough to spark and melt a tiny hole (maybe 1/8” in diameter) in the wrapper. There’s also a pinhead size spot on the metal battery case where the metal strip made contact.
Voltage of the battery matches all the other ones in the pack. Could any damage (other than to the wrapper) been cause by the momentary short?
It’s a Sanyo battery if it’s makes any difference.
Thanks
It will be fine. I have had much bigger more scary accidents than that and the cells have been fine. The fact that the resting voltage is the same as before tells you it didn't discharge much energy.
That’s great to know…thanks for the prompt response comfy.
If it'd been a longer duration event and the voltage was down a bit, it would be worthy of further checks but as it is the voltage tells you all you need to know.
I have noticed that if a cell is sitting at a VERY low voltage, <2.5V a short, short :slight_smile: like that can kill it. 3V and above no problem. That is at least what I have noticed.
He is good for that
For sure!
BLF is full of really helpful and knowledgeable people. I’ve learned a lot in the time I’ve been here, and also put a dent in my savings :slight_smile:
