Brightest 3535 Emitter at 3.5 - 4 amps?
What is the brightest white 3535 Emitter at 3.5 - 4 amps?
I’m thinking it’s the LH351D 70 CRI but I figured I’d ask here before I order them.
I would also check the Cree XHP35.2
The xhp3535 is NOT a std 3 volt emitter; it is only available in 12 volts. The LH351D IS a 3 volt emitter, same as the Cree XP and XM family and the Nichia 219-319-519 family and the SST20
If you stick to similar color temperature and similar CRI ratings it is probably difficult to actually see any difference between the output of any of the name brand emitters. Datasheets may show differences in lumens per watt but the eye cannot see most of those differences. Probably the newer the design, the more lumens per watt. CRI and CCT have large effects in making more or less lumens.
That is my opinion agoing by my own eye experiences.
Sorry, I forgot to mention I was looking for 3v Emitters only.
The brightest I could find so far is the LH351D 70CRI 5300K - 500 Lumens @ 1amp.
