Maybe.
XP-L Hi seems to make a fair difference!
Thanks for the clear beamshots, Steve. Actually I like the C83 best :bigsmile: , but I do not know what flashlight that is??
with a samsung 25r
Got around 60kcd stock
130 kcd with xpl-hi + removed driver
150 kcd with xpl-hi + removed driver + spring bypass
Cheers. The old XR-E @ 2.1A is fun in this light. Very narrow beam and long throw. ![]()
When you get sent to the dog house the missus ain’t foolin’ around.
I dont know many women folk that fool around RBD. Unfortunately I'm about 5 times bigger than the dog house and with the sacked assistants trying to get in there isn't a lot of room.
I'm sure you remember the C83 djozz as you were the second person to comment. It still brings a smile to my dial on high.
Link to C83,
Holy crap that’s awesome.
Could I put this reverse clicky switch into the B158?
If not, which one?
I haven’t received the light but from what I understand it comes with a forward switch. But I’d love a reverse switch.
Does anybody know how/where to obtain XP-E2 size centering rings for the spare pills? All the spare pills I got are sized for XML size emitters, but I wanted to build them with XP-Es. I think I need the white and the black pieces.
I emailed Brinyte, but haven’t gotten a response yet.
XPE is the same as XPG, Nichia 219.
Edit - Hoop can cut you something custom if you need it but an aspheric lens doesn’t need a centering disc if the mcpcb is the right size. Just black out everything that shows.
Yep - I gotcha on the sizes.
The pill has a 19mm opening, my Noctigon MCPCB is 16 mm. I don’t have a way to accurately turn down a 20 mm MCPCB to 19 mm.
My plan is/was to use Arctic Alumina on the MPCPCB and tighten down the factory centering ring. My red light came with the centering ring appropriately sized for the XP-E led. My extra pills came with XML size centering rings that are way to big for XPE/XPG/Nichia 219 builds I planned.
I was hoping someone had a lead on factory parts b/c Gearbest and Fasttech do not have them.
I should add that I just received an email from Brinyte. It was actually their second attempt as the first email went to my junk folder.
I’d have to double check, but I’m pretty sure I used the Convoy XP-sized centering rings (for say a C8 or L2) when using an XP-L or XP-G in my B158 builds
You can get them from Mtn here, or directly from Simon (Convoy) on AliExpress
Thanks, the MTN electronics spacers worked great.
Great, glad it worked out for ya. Happy modding!
Hey everyone just got two b158’s, excellent quility! I want to get a new driver, a 17mm-mtn-ddm. Does the tail switch need to changed? I think it’s a forward clickie, it’s not like a x5 or x6 tail switch. If it doesn’t need to be changed how do you get into configuration setup i.e.: 16+ taps and mode changing. Thanks for your help!
For a forward clicky, you would get into configuration the same way, except you’d have to either hold the switch in, or fully click it in to see the config options.
If you have a spare reverse clicky tailswitch in the same size pcb, you could swap it in. I did so on mine, and while its not a perfect fit, it works.
I have a few B158B hosts on the way and will be installing my own drivers in them. Can anyone confirm the original driver size without the brass ring? I want to adjust the diameter and make new specific versions of my drivers for these hosts.
The original driver size in all the ones I had were 17mm in from memory an 18mm OD adaptor.
