I have brinyte DIV10 Can light. But the factory offer me a two bay charger. As you know DIV10 Run in 3pcs of 26650 batteries
I can not charge my battery at one time by two bay charger. So I check on the internet . And I found a 3 bay 26650 charger from Trustfire
I’m afraid we don’t trust trustfire chargers or trustfire batteries. I always advise people to avoid trustfire, ultrafire, _any_fire.
Instead try Evva, efest or king kong 26650s.
We don’t need this:
“The charger passes the 2500 volt test, but failed the 5000 volt test, i.e. it is not completely safe in 230 volt countries.
Conclusion
The charger does not use the correct charging algorithm for LiIon and charges with to high voltage, but does not overcharge the batteries. It is not very good, but can be used.
The charger is not useable for NiMH and it looks like TrustFire do know it, but forgot to change the manual.
The support for large LiIon batteries and for IFR LiIon batteries, means that the charger can be useful, even with all its faults.
I am not impressed with the usb output, it is missing a low voltage disconnect.”
From HKJ test
There is not a lot of 3 bay chargers, instead look for 4 bay chargers. Maybe the nitecore D4. Not sure it fits 3 26650s.
Even if we can’t find any good chargers that can fit 3 26650s at the same time, its better to use 2 chargers than to use a bad charger.
I think Trustfire batteries are an exception from the bad bunch. They’ve proven reliable to me during many years, I’ve got 18650s 4-5 years old with 80-90% capacity, and never an issue with them. Also I’ve seen only positive reviews of them. Don’t know about their chargers though. There are fakes probably, as with any batteries.
