Brinyte XP22 dual head weaponlight
SEE MORE DETAILS:Click Here-XP22
【Features】
Electronic lock key design
Special magnetic charging design, charging faster
Tempered glass lens, anti-abrasion,anti-scratch, and drop-resistant
With overcharge, over-discharge and overheat protection functions Vertical switch design, holding the gun more convenient and stable
Charging intelligent power indication design, with flashing, instant lighting, and other functions Equipped with 900mAh integrated li-polymer battery, more durable and long-lasting
The screw rod is fastened and assembled on the gun body to easily resolve the impact of the gun’s recoil
Using aviation-grade aluminum AL-6061-T6, and military-grade 3 hard anodized on surface
Brinyte PT28 palm-sized tactical flashlight
【Features】
Compatible with one 18650 battery or two CR123A batteries, working voltage: 2.8-6.0V
Magnetic charging system, easy to charge
Intelligent power indicator design
Color temperature 6500K
Regulated power supply maintains constant brightness
Overcharge, over-discharge and overheat protection
Reverse polarity protection prevents damage from improper battery installation
Alloy aluminum reflector with professional optical analysis
Aircraft-grade high strength aluminum AL-6061-T6 with premium Type III military hard-anodized anti-abrasive finish
Brinyte PT18PRO tactical flashlight
【Features】
Brinyte patented tactical ring design, easy to grab at top speed
Fast charging function
