【 Brinyte XP22 Tactical Light】
Learn More:Brinyte XP22-Amazon Link
Adjustable Rail: Slide the rail adapter back and forth freely to fix the light in the desired position for your specific item, making the XP22 more flexible to use.
Huge Performance: 400- lumens;230 meter beam;Runs 1.6 hours.Performance comparable to mid-sized weaponlights.
Lock Function: XP22 has lock function, please unlock fiirst after receiving it.In the ON state, press and hold the switch for 5s to enter the locking mode, and the it will flash twice to remind when the switch is locked successfully ; After the key is locked, press and hold the switch for 5s,then the it will flash once to remind it to unlock.
Convenient Magnetic Charging: Charging by connecting the light directly with the included magnetic USB cable. There is no need to remove a battery or plug into a port that will wear out over time.Quick and wear-free removal for the quickest use of the light at any time
Vertical switch design: holding the item more convenient and stable.
Easy to install: Quick install and removal ; Ultra-compact and lightweight.
Strobe mode:In non-locking mode, double click into STROBE mode and click again to turn it off. PS: Press the switch slowly after turning it on - if you press the switch a little shaky, you’ll also get a double-click effect.
