Finally had good enough weather to get my Tom E modded Supershocker out for beamshots. I wanted to see just how well this beast stood up to a couple HID’s. So brother and I headed to our usual park to do a few moderate distance shots. I also included a couple other lights too for comparison sakes.
The lights -
TN31vn (XML2 dedome)- 1740 lumen - 495k
TK75 (XML stock)- 2925 lumens - 94k
Yezl (85wt HID, 4300k) - 4720 lumens - 291k
BTU (XML2 dedome) - 4260 lumens - 477k
FF4 (60wt HID) - 7010 lumens - 430k
Personally I think the BTU did pretty darn good vs the HID’s. I feel it easily beats the 85wt Yezl. And I feel its very comparable to the FF4. The FF4 had a very nice fat spot, where as the BTU has a slightly more intense spot and awesome usuable spill as the 2nd set of shots clearly shows. The TK75 I put in there for a standard in powerful triple lights. The TN31vn I put in simply because its one bad arse light and the King of LED throwers. The BTU actually gives it a serious run on spot intensity though.
The first set of beamshots is a treeline at 105m. Trees tend to suck up lux, but they are good for showing spot size and spot intensity.
The shots -
TN31vn
TK75
Yezl
BTU
FF4
This next set is shot over a football field aimed at its scoreboard. Shows flood and spot nicely for these lights.
Distance is 120m -
TN31vn
TK75
Yezl
BTU
FF4
Great set of shots.
That shocker certainly holds its own, but the FF4 is truly one hell of a light. For me based on those pictures the FF4 is a clear winner, its massive spot but huge range is simply awesome.
Its funny, just early tonight I had my TN31, TN30 (both XM-L2) and FF4 out showing a mate who isn’t “enlightened” and even though the Thrunites are both stock they still have that wow factor, but the FF4 is just in a league of its own; the sheer amount of light it puts out is impressive.
Kinda funny, to me the BTU is the clear winner
Look at the useable flood the BTU has along with a its nice fat spot. The FF4’s spot is clearly bigger and its foreground is brighter, but its only fair on its spill. Both have pretty intense spots.
Either way I feel they are pretty even. Basically its a matter of what you prefer in a light. But for a LED to even compare to a quality high output HID is an accomplishment itself.
Very nice beam shots. Thank you for the time and effort. That BTU is impressive for sure. Do you know what temperature bulb you had in the FF4?
I’m pretty sure its 4300k just like the Yezl has. Suppose to be best for power output on HID’s.
I find it interesting that the BTU and TK75, both with tints somewhere around 5-5500k I’d guess, have much nicer color rendition. To my eyes anyway. Look how nice and green the grass is on those two lights. Though I admit I prefer cooler tints.
That’s pretty much it right there. For me a little bit of spill is nice, just enough to light up the area enough to see but being able to light up a really big area at a very long distance is what I like 8)
I completely agree that for an LED based light its certainly doing very well to be up there with arguably one of the best HID lights available.
Just want to ask about color difference before read this. That looks much different.
Thanks rdrfronty and manxbuggy1.
I much prefer the btu’s colour rendition in these shots, the firefox 4 and yetzl both wash out the colours like any bad cw tint.
Thanks for sharing these great beamshots
Agreed.
The FF4 is a very impressive little light though. I’ve had other HID’s in the past and have always been disappointed with them. I hate waiting warm up periods and even output on the 35wt model I had last left something to be desired.
But the FF4 has changed my attitude somewhat. I’m actually quite fond of the powerful little bugger. Still don’t like the wait for warmup and think the UI is pretty weird though.
But by far my taste is for these powerful LED’s like the BTU. Beautiful colors with it and amazing power. And the TK75 holds its own considering its stock. The TK75 actually has a wider flood, but the modded BTU’s has more lux in its flood & is thus more useable spill.
Hey Brothers, thanks for your efforts. Very nice photos.
So.. the BTU shocker features 3 XML2s without dome and still is said to have an output of 4200 lumens? I dont really believe that, does anyone have numbers for proof?
Other than that, great beamshots, thanks. :)
NightCrawl, I know that these numbers sound incredible but if you will check Tom E’s ” I am shocked by this shocker” thread you will see that his numbers are very close to ours. This shocker is with the IOS driver which is direct drive on high and putting out 6A. Also it seems (to me anyway) that these XM-L2’s are loosing very little in output after de-doming and getting huge increases in throw.
No - de-domed Shocker loses lumens.
bluebll8z's Shocker: On Samsung 20Q's, 5.60A, lumens: 5,440 @start, 5,114 @30 secs, 240 kcd throw measured at 5 m.
Oh - nice shots!!
Is 1,700 per LED hard to believe? I don't think so... Mod'ed TN31's get 1,700 de-domed, and the Shocker has basically 3 C8 reflectors. I've measured 1,500 lumens on HD2010's and the XinTD X3 at lower amps.
Yeah these XML2’s do lose some lumens, but not too bad. So with the dome these Supershockers are getting 4500-5200 depending on where driven at 5-6a. And without the dome they should be in the 3800-4300 range depending on the 5-6a they are driven at. So roughly 1700 domed and 1400 dedomed per XML2.
Dang Tom, have you tried a TN31 driven at 6.5a WITH the dome yet? That sucker would have some very nice lumen numbers with its bigger reflector.
You guys make me wish I had Tom E de-dome my BTU Supershocker when he upgraded it for me. Also, I was forced to purchase an FF4 after your last beamshot comparison. Stop making me spend all of my money!
A bridged TN31 would do over 2,000 lumens, sounds crazy and doesn't seem to fit Match's results, so I'm not sure what's goin on. Could be these high lumen multi-emitter lights is messing with our PVC pipe light box, or, there's some other factor involved, or we are messing with the meter's calibration at these high levels, dunno. Could be Match's test environment and the emitter variations - lots of possibilities. I do like the Noctigon's better than the SinkPAD's at high amps though - lower resistance in the traces. But the TN31's star is at a whole different level - huge in diameter and thickness and a direct thermal path.
There's a few guys building direct drive or high amp driver single LED C8 size and above lights, but not too much info out there on measured lumens. I've generally constrained my mods to 4.5A or so, mainly because that's all you will get anyway, but maybe something like the T08 could go in the 5 or 5+ range. I should really build out my 7G9 to 5+ amps because with it's 3 parallel cells, should support high amps on an XM-L2.
That's what makes this Shocker pretty unique in that you can get high amps out of the configuration, like the TN31/SupBeam driver.
I wouldn’t worry too much about it. Tom did my first BTU way back. Nobody was messing much with drivers at that point or even the light itself. But he did do the xml2’s on copper, better wires, and spring mods. It’s at 3745 lumens and 184k. And truthfully I love it just as much as my recent Supershocker. My first one still has VERY good performance numbers, better than a RC40. And it’s as usuable as a Big heavy BTU can get - full regulation and decent runtime while running on 3400mah cells.
If I had to choose between the two, it would be a very hard choice to make.
Basically any modded BTU is a great light to have. And thanks to Tom and a few others, we have lots of options for these BTU’s - regulated or non regulated, dome or no dome, moderate amps or high amps, one with pure brute force but limited runtime or one with great power and pretty decent runtime. All BTU’s are beasts ![]()
That BTU is a real shocker. Orsm light. I hope you guys are looking after my carry case? ![]()
Did anybody ever notice what bin or color temp Match used in his tests? Tom, I know you used U2’s in my 4200 dedomed BTU and your latest 5100 domed one - where both of the 1a’s? I was thinking you said my dedomed one was perhaps 1c? Not sure though. The tint is nice to mine though. Great tint for a dedomed XML2. To me anyway.
