As you stated, it's imperative to have set guidelines if the testing is to be done among different people with different equipment. Even with that, I'm sure it will introduce another margin of error.
Another thing to think about is that our favorite chineese vendors are notorious for having quality fluctuations(nice way to put it) with any given product...I see no reason batteries would be excluded.
this is very true ( i have had bad luck with 18650 trustfire flames from dx)
but diff equipment will only have slight errors and we should post the equipment used to test in a line, that way people know how accurate the info can be
Old already started a thread, but its not the same as say a PDF file he keeps running with people droping him the info to add to it
Old, would you want to do it that way? easier to follow that way
I can maintain the information in the first post of such a thread ..
And update as new information is added .. Whether posted in the thread or emailed ..
I was planning on setting out a format + guidelines to be hashed out ..
Yes there will be variance , but as long as the equipment is ok , then it will be a small variance .. + There is always some difference from one lot to another ..
Nothing can be done about that , no matter who tests what ..
+ The thread I started was more or less just a test = The real deal could be made a Sticky ! [ Admin ? = we would need to co-ordinate ]
My Pro-Peak Prodigy gives nice accurate numbers. It's only failings are it's 0.5A discharge rate & due to it being several years old it can't handle LiFePO4's or any thing else that needs a new charging schema.
As you're thinking of testing smaller batteries at 0.5A, I'd be more than happy to help out when ever I have suitable new cells. I've have some in the post that are bound to arrive *eventually*
Sorry for the delay on this! I'm behind on everything due to an unexpected 10 hour power outage yesterday...
Sounds like a great idea Matt! I can make it sticky, or even put a link on the main left menu. Just let me know what sort of IT support you need. You could use the table system on the forum if you like, or I could create a new type of post with structured input fields too. Just let me know. Thanks for your initiative!
Nice idea Would be great if someone can explain how to obtain those numbers. I mean, I don't have any display on my charger, is there any way to "calculate" those "mAh" or "Amps"? I have a multimeter but don't know how to do it
