I am learning here so I appreciate any help I can get.
This build is for a stage prop for a children’s dance performance school. I hope to create an effect that flash about 2000 lm for 5 to 10 seconds and be repeatable. The LED assembly will be build into a physical prop TBD.
So based on what I know now I am thinking about 2 LEDs in parallel with a DC to DC buck driver.
If I wire 2 batteries in series the output would be approx. 7 volts to the buck, The voltage and current will be limited by the buck to 3.7v and 2000ma as measured with a multimeter (which I didn’t want to buy but since the buck is adjusted with a POT is seems this is required.) Then the LED’s follow the buck in parallel.
Just need a switch, and probably a heat sink.
Please let me know if I am going down the right path or if I will blow myself up.
First you will definitely need a heat sink, no question about it. It doesn’t have to be a big finned thing like in a computer but count on using a solid piece of Al or Cu, try to run emitters at any kind of current, even for <10sec and you’ll fry them.
Next your not going to get your 2000Lm from two emitters in parallel at 2.2A. At 2.2A a single XM-L2 makes ~800Lm (bare emitter lumen, not figuring in optical losses), at 1.1A per emitter your looking at <1000Lm total. Minimum you’d need 2 XM-L2’s @ 5200mA (2.6A/emitter) to get to 2000Lm. Add a third emitter and you could lower your current about 500mA (1.6A/emitter would give you ~650Lm/emitter making your 2kLm).
Also about your battery choice, do you already have a 4.35v Li-ion charger? If you’re going to have to buy a charger I’d go with a standard charger and standard 4.2V batteries. The nitecore i4 is a great 4.2v 4-bay charger and can be had new for <$15 on amazon.
One other thing, if you are in the US and have a harbor freight near you they have a coupon mailer a few times a month and almost always include a coupon for a free DMM, not the most accurate DMM but should do what you need and save a few bucks. I think we all know what its like to work with a limited budget and every penny saved helps. Good luck.
Edit: question for you, what sort of optic are you looking at? What sort of beam pattern do you require? All light flooding out in one direction? Or do you need some sort of concentrated beam of light (cause that would take some sort of lens/reflector). I imagine you know this but the light from a bare emitter will be very wide and not focused at all.
Agreed, got it.
Yes I guess I missed the 3A spec to get 995lm on the LED I was looking at.
_
Minimum you’d need 2 XM-L2’s @ 5200mA (2.6A/emitter) to get to 2000Lm. Add a third emitter and you could lower your current about 500mA (1.6A/emitter would give you ~650Lm/emitter making your 2kLm)._
So it sounds like more emitters is better, no problem.
_
_
Yes I am starting from scratch.
_
One other thing, if you are in the US and have a harbor freight near you they have a coupon mailer a few times a month and almost always include a coupon for a free DMM, not the most accurate DMM but should do what you need and save a few bucks. I think we all know what its like to work with a limited budget and every penny saved helps. Good luck._
Thanks, free is good, but I do like accuracy too. I can pop for something, but it is a little confusing when the prices range from 18 bucks to 800 bucks.
_
What sort of beam pattern do you require? All light flooding out in one direction? Or do you need some sort of concentrated beam of light (cause that would take some sort of lens/reflector). I imagine you know this but the light from a bare emitter will be very wide and not focused at all._
Is there a good place to shop for reflectors?
_
Best to avoid series 18650s. Parallel is much safer. Then go for a 7135 driver and 3 or 4 XMLs.
_
Why can you say more about what could go wrong?
_
Flash as in strobe or just on for 5-10 sec then off?_
The circuit will be on a momentary button, so the kids can push it for a short amount of time and then when they move on the light goes off.
With serial li-ions one battery can discharge faster then the other and can become reverse charged. Quite dangerous. Li-ions can explode or “vent with flame” releasing toxic gases. Serial can be done safely but most should just avoid it IMHO. You would need a different driver, one with low voltage cut off. Batteries need to be LiMn or Li-ion with quality seiko protection & kept balanced.
There are actually several different options, a standard reflector, an aspheric lens, a fresnel lens, a TIR, maybe even the bare emitters are what you need. If you tell us what your needs are we can better help you. Do you need a piercing beam of light that shoots out of a single point, or do you need bright diffused light that emits out one entire side of the box or what?
Also about how much total time per show (or per day) will this be on? Trying to figure out how many batteries you’ll need to use to get the needed run time between opportunities to charge/swap batteries.
As mentioned I highly suggest you use either a single cell (if it can provide the needed run time) or cells in parallel, especially being operated by kids I’d hate to see an accident.
Please keep us updated, this is a cool project, I’d like to follow it.
