thijsco19
(thijsco19)
11
In series the amperage would still be 2.4A but the voltage will be higher.
In parallel the voltage stays the same but the amperage is increased. The amperage will be shared between each led.
BlueSwordM, with that setup there is no need for a buck or boost driver. You’ll need a linear driver do have regulation.
The above named drivers could work.
Another option is the LD-A4 from led4power.com.
https://led4power.com/product/ld-a4-2-12amp-17mm-constant-current-led-flashlight-driver/
